Question about Whirlpool GU2400XTP Built-in Dishwasher
Proceedure to winterize washer
I have a Whirlpool GU2300XTSQ0 disherwasher. It is installed in an unheated summer cottage. What is the procedure to winterize this machine to keep it from freezing up over the winter?
  • 943 Answers
HI thanks for your question. the easiest way is to. pour plumbers anti freeze in it 1 gallon should do it . thanks the appliance doc. oh, start it up in the wash cycle for a few minutes, to cycle the water.
Posted on Oct 13, 2008
Can I leave a dehumidifier in an unheated cottage for the winter? Where will my answer appear?
you can leave it turned off emptied in the unheated cottage. but i would not reccomend letting it run or stay with water in the tank. as water expand when it freezes. and will break the tank. also . dehumidifiers do nothing in freezing condition other than waste energy. so empty the tank and store it for the winter.
and your answer will appear right here :)
Nov 08, 2016 | Dehumidifiers
Can I leave the dehumidifier in an unheated cottage for the winter
yes but make sure you cover it over with something
Freezer in unheated/unairconditioned garage it stays cold in winter time but it is not freezing when the temperature is hot in the garage
The first thing is to find out if there is a fan that runs next to the compressor. If not then in the summer the machine is overheating and passing the heat up to the machine itself thawing or preventing the freezer from operation properly
May 17, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Do i need to winterize front load washer
If your unit will be in an unheated house you should. There will always be some water in the drain line and the bottom of the tub. Most of the water in the tub will evaporator so it isn't a big concern, but the water in the drain line and drain pump is.
Aug 18, 2011 | Kenmore 44832 Front Load Washer
Problem with ice maker on Whirlpool fridge
2 things, Usually when you disconnect the water the rubber seals stick to the plastic walls of the inlet valve housing when the water evaporates. This is the most common cause.
The other is the module linked below goes bad. If you remove the white cover on the front of the ice maker most times you will see a tab broken off of the larger gear in the center. A picture of the module is linked below.
Ice maker module.
May 21, 2010 | Whirlpool ES5FHAXS Side by Side...
How dow I winterize LG front load washer?
very simple
get a towel
take off the back wall
remove one of the pump hoses
id remove the front one since the back has a check valve
let the machine
drain and you should be fine
you can eith recoonect then or when you get back
Oct 07, 2009 | LG WM-2077C Front Load Washer
Closing down my summer home for the winter. will my vizio lcd tv freeze if i leave it in a unheated house?
no but it may not be there in the spring
they are easy to steel but any way just unplug it and it will be fine.. in the spring it might be dime when you first turn it on floresant tube will do that when they are cold
Sep 28, 2009 | Vizio GV42L 42 in. LCD Television
Worried about winter storage
Extreme low temperature may effect the operation of the electronics, but unless you plan of using them in a freezing environment there will be no ill effects from the cold. These units are shipped in unheated trailers all over and routinely are exposed to freezing temperatures.
Thanks for using Fix Ya, please take the time to give this solution a Fix Ya rating.
clarkco
Feb 06, 2009 | Kenmore 44102 Front Load Washer
Whirlpool GU2400XTP Built-in Dishwasher Logo
787 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
