Question about Microwave Ovens
Panosonic Microwave convection Model NN-8501V Touchpad appears dead
I have a NN-8501V unit and all the sudden It will not work at all, like a fuse in the unit blew. (is there one in the unit?)
The outlet is working and when you open the door the light comes on, but the touch pad on the outside is dead, does nothing. Worked fine last week.
Any ideas?
Also need to know where to find a users manual.
  • 2 more comments
  • ttcorn Oct 03, 2008
    The website you sent me to for the manual says the manual does not exist for that model.
    No matches can be found for the NN 8501V.
    link for manual can not find the manual for this model #.
    Also question about microwave not working was not answered.
    Ok so where do I find this ribbon cable you are talking about. This is an installed Microwave in
    my motorhome. Do I get to this from the back.
    complete Model # is NN-8501V
    email is ttcorn@yahoo.com
    Sergeant:
  • 409 Answers
since the lights are on that means you have power to the microwave.
the only thing that does not work is the keypad.
that could be for one of 2 reasons, the keypad itself is faulty. it's attached to the control board behind it with a ribbon cable, so the cable is the only thing that could be faulty.
the other reason is the control board behind the keypad. the fuse that you are looking for is saudered on the control board, so if the fuse goes, you'll have to replace the control board.
i would start with the keypad first.
if you can provide me with the complete model # and an e-mail address, i will e-mail you the user manual. i only have access to the Panasonic dealer page but it's password protected.
thanks
Posted on Oct 03, 2008
  • Carmen Mikulic Oct 03, 2008
    hi there,
    you will have to pull the microwave out since it's an OTR.
    the ribbon cable is attached to the keypad from the inside of the microwave, which you won't be able to see unless you take the keypad off.
    here is the exploded view and parts breakdown for the better reference.
    http://servicemanuals.panasonic.ca/viewi...
    take a look at this diagram, it will give you a better idea of what you need to do.
    thanks
  • 958 Answers
There is a fuse inside and if it is busted, i think you would not even have a light.
i'm thinking the system hanged. you can try opening it up, remove the the ribbon cable from the touch pad to the main board. this would reset the touch pad.
after 10 mins, plug it back and see if it will work.
if it will work and the problem would re-occur, the problem is in the main board.
tnx 4 using fixya,
drcool
  • francis rivero Oct 03, 2008
    hi ttcorn,
    the ribbon cable is inside the microwave oven. you should bring it down first if it is installed in your motor home.then remove the housing of the microwave and you can see the ribbon, it is a flat thin strip of material that is locked in the main board. there would be a clip that you need to lift before you can remove the strip.
    tnx again,
    drcool
    Genius:
  • 1,124 Answers
    Genius:
  • 3,422 Answers
HI,
Disconnecte power and remove the top of the microwave oven. loosen the touch panel (one screw holding it on the inside - yours may be different). Several wires running to a circuit board on the touch panel: loosen only one wire (a green ground wire) -
The touch panel has two parts: a circuit board screwed to the back of the panel with 2 screws and the touchscreen itself built into the panel. Remove the two screws and the panel (with touchscreen) which will completely free of the circuit board.
  • Priya darshan Oct 03, 2008
    Now see what connects the circuit board and the touchscreen - a very
    fine and narrow strip connector. If you look at it with a magnifying
    glass you will see that it is a connector of some sort: it presses into
    a corresponding connector on the circuit board.the connection (which relies on pressure and position) may be worn or loose or dirty over the years possibly due to relentless
    pressing and punching of the panel buttons and the door opening button.
    find a small smudge of material on the connector and remove it
    with your fingernail. Replace the circuit board, be careful to
    position it properly, and tighten the screws, reconnect the green
    ground wire and test the unit.
  • Microwave Ovens Master
  • 19,396 Answers
The unit has a fuse in the power board, but when the fuse is gone it does not even start up. If it starts it is not the fuse.
Look rather a problem with a faulty touchpad, or the magnetron that is not working and need to be changed.
Check also the door sensor.
Panasonic convection oven nn-cd989s, complete power off during prebake cycle of 450 deg which was directed to remove light oil coating from manufacturing process . Now unit has no power on face panel
Check the 20 amp fuse where the power cord ends inside the oven. If it is open check the latch switches. If the switches check ok the invertor is probably bad, smoking.
Dec 20, 2014 | Panasonic Genius Prestige NN-CD989S -...
My Panasonic Dimension 4 microwave/convection oven (NE9870) is dead. It was running, produced a small popping sound and is now completely dark. I've tried alternate electrical outlets and there...
Ken,
Usually there is an internal fuse and that is probably your problem. You will need to take off the outside cover of your microwave and then look where the power cord goes into the back of the unit. Look for the black wire coming out of the power cord and follow it. It should take you to the fuse. Hope this helps!
Dec 16, 2014 | Panasonic NN-T888S Convection/Microwave...
NN 8501V Panasonic Dimension 4 Convection/Microwave oven keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Apr 16, 2013 | Microwave Ovens
I have the same problem with Panasonic NN-8501V Microwave Oven
I took the touch pad control unit apart, clean the connector for the ribbon wire connection between the key pad and the control unit, reseated the ribbon wire in the connection. Everything worked like new.
Oct 16, 2009 | Panasonic Microwave Ovens
Our NN-8500/NN-8501V Micro/Convection is no longer repairable
hi Peggi and john, have a look here for repairs and new in Dallas TX area:
http://www.superpages.com/bp/Dallas-TX/Affordable-Appliance-Repair-L2069127442.htm?SRC=portals&C=Range+%26+Oven+Sales+%26+Service&lbp=1
regards from the UK :)
Nov 21, 2008 | Panasonic NN-T888S Convection/Microwave...
Panosonic nn-t790 microwave
I pulled the top and sides (one piece) of the microwave. Near where the 110 volt line goes into the unit is a standard fuse ( 18 amp). I used an ohmeter on ther fuse and determined that it was not working and replaced it. Problem solved - unless it blows again.
Nov 06, 2008 | Microwave Ovens
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic Dimension 4 microwave model NN-C703BBPQ not working. Display is not illuminated as if fuse has blown. Have changed fuse in plug, but still no visible sign of life. Anything obvious that might...
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Jul 29, 2008 | Panasonic Microwave Ovens
RV Microwave/Convection by Panosonic Model NN-8501V, touch controls go crazy when cold, indicating the AUTO DEF button is in continuous contact. CLEAR/STOP only works for a second and then AUTO DEF starts...
I tried looking up the part number for this model and they don't identify clearly what the touch pad is. Would have to get one of the parts companys (andrewselectronics.com) to do research on it.
I've done surgery on a few touch panels and it usually works out. Have to break through the plastic tabs holding it together, then you can clean the contacts. Then do something like find little tiny screws to fasten it back together.
Hope Ya Fix It!
Jan 24, 2008 | Microwave Ovens
Microwave Ovens Logo
164 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
