Lg intellowasher DD 7.5kg WM14225FD error code OE
  • rrzijlmans Apr 11, 2009
    well hello i have the lg intello washer dd 7kg wd1485fdn
    ok i start; welkoms beeb i set the program but the machine goes beeb beeb and "de "is flashing in the display. i cheked the filter and it was not stuck ore dirty and the little fan inside was tight so wat now:??
  • 1,543 Answers
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Posted on Oct 01, 2008
Hi my LG intelliwasher 7.5 WM 14225FD is leaking underneath can you tell me what could cause this
Posted on Jul 15, 2010
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Feb 09, 2011 | LG Washing Machines
What does OE mean on my LG intellowasher frontloader
its a open door error its because the door is not closing all the way.
Dec 27, 2010 | LG Washing Machines
My LG intellowasher 7,5kg WD- 8016c is flashing the letters OE Can you please tell me what this means
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Washing Machines
LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | LG WM1814CW Front Load Washer
My lg intellowasher wd1290 error code OE
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG intellowasher DD WM1480 FDH washer displays DE (door open) and refuses to start, if I repeatedly open and close door sometimes it will start or the door will lock and it still doesnt start.
I have this problem too for my LG Intellowasher. I suspect it is because you're selecting "Rinse Hold" from the options. Try turning the power off and washing again on another setting to see if this resolves the issue.
May 03, 2008 | Washing Machines
Washing Machines Logo
2,231 people viewed this question
Top Washing Machines Experts
