Question about Patton POH2520-U Oil Filled Radiator Heater
Northman Oil bath radiator Model # OFH-3600.
Please notify me if this service costs anything before moving forward.
I have a heater that was given to me that after taking it out of the box would not turn on. It is brand new and i can't see any signs of damage. Any ideas? I can't even find the manufacturers contact info. Not sure if it is possibly manufactured by someone else - like Patton? Any suggestions on fixing it would be helpful. thnks
2 Suggested Answers
SOURCE: Patton ceiling heater Model# 2433
x48987
Posted on Jun 09, 2008
1991 dodge dakota heater vacuum air flow shutters son't move
Taking your heating box apart may be a really big job.
It would be good to check the vacuum supply at the heater box, and/or at the controls.
Lack of sufficient vacuum can cause the heater to not work.
The low vacuum could be due to a vacuum leak somewhere before it gets to the controls or the heater box.
Then, the heater box or flaps could be stuck or warped, causing malfunction.
It is all repairable, but can cost you a lot of time and effort fixing this.
God bless your efforts.
Dec 22, 2015 | 1991 Dodge Dakota
Drivers power seat wont move forward. Can't push clutch if I can't move the seat forward
Check the two fuse boxes (use your smartphone camera and flash) for anything burned out . Note: There are two fuse boxes, one inside, under the dash and another by the engine.
Owners manual will help you locate the seat power fuse.
Dec 06, 2015 | 2005 Volvo S40 2.4
Heater jacket was replaced by our local engineer who charged us RS.850 as cost of the jacket.Is this the genugine price. Regards. Ajay
If you were given a genuiene repair bill with the details mentioned of the heater then the cost must hold good which can also be included with the service charges.
If there was no bill given you can make a call to the local support center and report the matter or clarify as it is important that the service bill must contain all details.
Sep 01, 2011 | HP LaserJet 1020 Printer
I put in the wrong code for my phone, and now it's blocked and is asking me for a PUK code. I no longer have the box which has the PUK code on, what is the code?
PUK and PIN are two security features provided by the service provider. If given wrong more than three times, the SIM gets locked and has to be replaced by the service provider. And to retain the same number, you will be asked to pay a small amount. Please contact the helpline of your service provider and ask for a new SIM. Use your friends phone to do that.
Aug 09, 2011 | Cell Phones
I have a Pentair minimax 250k electronic. Opened pool today and when I turned power on to the heater, it won't get through startup sequence. Dashed lines flash, then 888 and service light comes on. ...
Most of the time I have found the problem to be the thermistor. It is located on the water manifold of the heater. Usually the panel lights, flashes then to 888 and back to dashed lines. SW light is green, and service light is red. It costs 25 to 45 dollars, and takes 5 minutes to repair. New thermistor looks identical to old so replacing it is very easy.
thanks please let me know if this was helpful
May 21, 2011 | Pentair Minimax NT Heater
The radiator has one holding bolt at the top and rubber mounted grommet at the bottom. Removal of the top bolt enables the radiator to swing forward but cannot be moved out of the way to get to the spark...
I use a SnapOn Universal joint coupling Plug spanner. With that, I can get in at odd angles.
Method.
Be careful not to damage the oil cooler and radiator fins!
Remove, Lower and upper cowl and wind guard.
Remove oil cooler upper mounting bolts and wire harness guide.
Disconnect fan motor sub harness (2 pin) and remove radiator upper mount bolt.
Remove the radiator from the upper and lower brackets by moving it to the left, then move the oil cooler forward as an assembly.
Remove the air guide from the oil cooler bracket and cylinder head cover.
Disconnect the spark plug caps.
Clean the area with compressed air to ensure no debris enters the engine.
Remove the plugs and check/clean/set/replace.
Jan 08, 2011 | Honda CBR 1100 XX Super blackbird...
Hi. I have a DeLonghi 3107 radiator-type heater, g...
Personally I would throw it away. those radiator type heaters were OIL filled when new ,not water filled
May 20, 2010 | Heating & Cooling
Oil-filled heater smelling
yeah they do that, time for a good cleaning, if that fails, I'd replace with a ceramic heater... they are cheaper safer and cost less to operate.
Feb 21, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Heating & Cooling Logo
503 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
tractorman44
tractorman44
Jay Finke
Jay Finke
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
