Question about Samsung SGH-D900 Cellular Phone
Dead I cannot switch it on nor charge it up. It just appears to be dead. Maria
  • ebby8471 Nov 09, 2008
    same problem nothing happening although
    keyboard does light up
  • sniper4real1 Nov 11, 2008
    the phone go off and i can not switch it on again
Less battery back up
Posted on Oct 01, 2008
  • harjeetjaid Oct 01, 2008
    sgh-d900 refresh code please tell me
About once every 2 to 3 weeks car won't start. Battery appears dead. Then next day fine. Battery holding charge, not starter either. Baffe
If the battery appears dead when the fault occurs, it probably is the battery (or pos/neg leads) batteries are devious and take pleasure in appearing fully charged. Eliminate further by replacing battery, buy or borrow. Only other explanation is a short to negative on particular day, check starter motor cables. Best of luck.
Mar 13, 2015 | 2007 Honda CR-V
Batteries go dead when you drive with the inverter on?
It appears that you are drawing more power when driving and using the inverter than the charging system can supply.
Sep 19, 2014 | Electronics - Others
My car mercedes c200 model 2008 the electric not on at the switch
do you see dash lights and headlights on when your ignition switch is on position if no check battery volts should be 12.5 volts.if not battery dead have battery checked out get it charged up.if battery dont charge up. it has a dead cell, if battery could be charged up,more likely alternator could be faulty causing dead battery. .
Sep 04, 2012 | 2008 Mercedes-Benz Mercedes Benz C Class
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
Battery not detected
Either both batteries are dead or your battery charging system in the computer is dead. Best thing is to try yet another battery or try your batteries in somebody elses laptop.
Apr 20, 2010 | Acer Aspire 5720-6661 Notebook PC
I have Nokia 1100, battery is dead & won't charge
I am sure if you take this to the nokia care they have an easy replacement for the battery.
Thanks
Fame !
Apr 27, 2009 | Nokia 1100
TX IS DEAD
The T3 will appear dead until the battery has SOME charge. A totally dead battery, even though plugged into a charger, will not let the T3 turn on. You mention a previous charger problem. Could be a bad charger, or a bad battery. Check to see if the charging light is on on the T3 when you think you are charging. If it is not on, try another charger. If it is on, you may have a bad battery.
Jim
Sep 09, 2008 | Palm Tungsten T3 Handheld
Lap top is dead
Do you have tried remove the battery and plug in the power cable and try to turn on the laptop? That could be caused because of the battery.
Try it and tell us more.
Nov 15, 2007 | LG X-Note LM50 Notebook
Samsung SGH-D900 Cellular Phone Logo
37 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
