Question about Intel 845GE Motherboard
Windows xp compatibility
While running windows xp sp2 ,set can not upgrade due to third party carnel
warning comes pls say what to do.
Actually the fix is pretty easy...
the reason the Winsvr2k3 upgrade prog is doing that is because YOU CANNOT USE A MODIFIED ntoskrnl.exe (to modify the win2k bootlogo) during the upgrade process...
Just restore the original ntoskrnl.exe (expand it) from the Win2k Server CD with the ORIGINAL BOOTLOGO and the upgrade should go fine...
The Microsoft upgrade prog. does a check on the ntoskrnl.exe file during upgrade i think and IT DOESNT ALLOW MODDED BOOTLOGOS!!! by wzoo1 source http://board.iexbeta.com/index.php?showtopic=20635 it work with me 100% thank you wzoo1
Posted on Dec 17, 2008
    President:
  • 2,351 Answers
Hi rjskmrr,
Please correct me if I am wrong. Your question is; While running windows XP SP2, setup can not upgrade due to third party Kernal. Microsoft is aware of this issue & has posted soulations on their web site.
(Vulnerabilities in Windows Kernel Could Allow Elevation of Privilege and Denial of Service). In other words windows will not allow you to update. Microsoft's work-around for XP SP1 & XP SP2 is too download their update & install. Please click on this Microsoft link:
http://www.microsoft.com/technet/security/Bulletin/ms05-018.mspx & at this link: http://support.microsoft.com/kb/890859
To fix this issue click on this link:
http://www.microsoft.com/downloads/details.aspx?FamilyId=F0683E2B-8E8F-474F-B8D8-46C4C33FCE99&displaylang=en One the site is loaded click on the word, " Instructions". Follow Microsofts instructions to repair your windows.
Good luck rjskmrr!
Mike
Posted on Oct 01, 2008
Mishraji your the besttttttttttttttttttttttttttttttt
Service Pack 2 (SP2) appeared on 2004-08-06. It is an important upgrade and should be installed on all Windows XP computers. The same is true for Service Pack 3 (SP3), which appeared on 2008-05-06.
However, due to the general tightening of security, there is the potential that some security measures interfere with special functions you had been using on your computer, and you may have to loosen some security settings accordingly. Given the complexity of some Windows XP installations, there is also always some potential for some other defect to show up.
List of fixes included in Windows XP Service Pack 2
http://support.microsoft.com/kb/811113/
Available disk space is used as follows (LIS = Local Install Source, the install files remain on disk; CAB = files of type .cab, cabinet).
Free disk space Features 600 MB Minimum for safe installation
(and safe operation of Windows XP) < 1.5 GB No LIS 1.5 .. 2 GB LIS and used CABs > 2 GB LIS and all CABs A general advice, particularly after changing hardware, is to power everything down, including any routers, cable modems, switches, hubs, and the like, wait 10 seconds, then power them up again. Rebooting without powering down is not enough in some cases.
Your problem may not be related to Service Pack 2 at all. If you have the firewall set up properly, but still have network problems, continue with the Windows Network Problem Solver page.
Microsoft offers free technical telephone support for Service Pack 2. In the US call (800) 936-5700 and press 0 to get to an operator. Ask for technical support on SP2.
This article does not generally cover installations running a third party software firewall. If you want to rely on the information given here, you have to completely uninstall any third party firewall software first.
Feb 14, 2011 | Microsoft Windows XP Professional With...
The Pinnacle Studio which worked on Windows XP does not work on Window 7. What upgrade software should i get?
I think the best option for you is to Upgrade to Pinnacle Studio 14 which is $0, or Pinnacle Studio 14 Ultimate, which costs $70. An upgrade is cheaper than buying the entire version which will cost you about $130. The upgrade will work with Windows 7, Windows Vista (SP2), Windows XP (SP3).
On the other hand, if a program cannot be run under Windows 7 because of compatibility issues, you can right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. This will make it run as if it was running in Windows XP. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 08, 2010 | Pinnacle Dazzle DVD Recorder
I am trying to load programs from old xp to new I am trying to load programs from old xp to new xp. I get explorer version update not compatible, Then old computer has newer version than new computer. Can...
You cannot upgrade (as you say load ) from Windows XP to Windows XP. You simply cannot do this and there is no point in doing it as I explain. You can upgrade Windows XP to Windows Vista easily. In the case that you want to keep Windows XP and want to enjoy better security and new features than what you do is you go to "My computer" icon and right click it and then take properties of it. The new page that will open you carefully check for these SP1(Service Pack 1), SP2 (Service Pack 2) or likewise SP3.
If you do not find any (SP)Service Packs than according to your requirement you can download and install SP1 or SP2.
Caution: The third level service Pack for Windows XP is SP3. Microsoft has declared that it is not for everyone. I strongly discourage you to install SP3 unless you have a strong requirement for it. After that you can put your XP on normal regular updates from Microsoft.
Good Luck!
Aug 11, 2010 | Computers & Internet
I cant find a driver to the motheboard i have
Here is a link to your motherboard. They don't have the Windows 7 drivers but you might be able to set the driver compatibility to XP. I'm not sure but its worth a try.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to change driver compatibility (this example uses Vista)
1. Right click on the driver setup executable file and select the Compatibility tab. Set compatibility settings to Windows XP (Service Pack 2), and set the program's Privilege Level to run as administrator.
2. Install the device drivers and reboot the computer.
3. Right click My Computer, select “Manage” in the new window select Device Manager. Select the unknown item on the list. Right click on the unknown and select Properties, and then select the Driver tab. Select the Update Driver button and let it search for the drivers. A warning will appear regarding the lack of a digital signature. Tell Windows to install the driver anyway.
4. Reboot computer.
5. Search for your xx.exe or open an Explorer window and drill down to c:\windows\wher driver installed
6. Right click on the exe and select the Compatibility tab. Set compatibility settings on the exe to Windows XP SP2 and make sure the executable can run as an administrator
Hope this helps. At least until they come out with the proper drivers.
Nov 08, 2009 | MSI MS-6702E Motherboard
How i can install xp sp2?
for bios update go to manufacturers website but to install xp sp2 on this lappy you will have to install third party raid driver and legacy device driver that you can download from www.download .com
May 09, 2009 | Computers & Internet
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Mar 05, 2009 | Acer Aspire 5610-4648 Notebook
Satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
Windows xp-winchat not working
Both computors must be connected to the same network{LAN} or Internet as you probably know.Also ,each computor must be running a similar Protocol,such as TCP/IP.Please also recheck the ip address and whether you have not been barred by your destination computor.Regards
Jun 09, 2008 | Computers & Internet
I have a Dell D620 laptop with an Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz running Windows XP Professional SP2. I have an old legacy program that fails to run properly, this issue is linked to the cpu...
One thing you could try (if you have not tried it yet) is to right click the program file, then select "properties" from the menu, then, when the properties screen opens select the "compatibility tab" and check the checkbox "Run this program in compatibility mode for", then choose an "older OS" for your program.
Apr 16, 2008 | Computers & Internet
Cant get modem share to work on my tablet... no com ports available
ModemShare is not compatible with Windows XP Service Pack 2 (SP2) or later, due to changes that Microsoft made to the DCOM security settings.
ModemShare is a now discontinued product, but the publisher provides an upgrade path to the replacment NetModem modem sharing solution here: http://pcmicro.com/modemshare/freeupgrade.html
Another option is to downgrade XP back to SP1, or use any version of Windows 2000 which is still compatible with ModemShare.
-Tim
Dec 21, 2007 | SpartaCom ModemShare Millennium (24-56200)...
Intel 845GE Motherboard Logo
197 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
