Question about Garden
John Deere LT190 Lawn Tractor transmission problem
Transmission grinds in forward and reverse. What is wrong? It will move when making noise but, very very slowly.
  • 6 more comments
  • ahschober Oct 01, 2008
    Yes it is a hydrostatic transmission. What does changing oil and filter have to do with the grinding problem. Its only 4years old and not that may hours on it. I will change oil and filter and if this corrects problem I will pay for answer. Is this acceptable for you?
    Regards,
    Alfred Schober
    Can transmission be taken apart and gears replaced. Or does the whole unit have to be replaced?
    I want to know if the gears can be replaced or do I have to junk the transmission and try and purchase a new hydrostatic transmission.
    I went and examined the transmission and my owners manual. It is a sealed unit. It has no place to add fluid and there is no external filter that can be replaced. Any suggestions?
    Do you know if the transmission can be taken apart? I Can't find an answer to this. I am sure a new unit would be very very exspensive.
  • abarsch May 11, 2009
    My new holland ls 45 ( same as toro 268H) goes in forward but has very little power in reverse
  • Anonymous Mar 16, 2014
    Yth21k46 huskavarna lawn tractor has grinding noise when brake is released all the way if I lift it a little noise goes away
  • Anonymous Mar 25, 2014
    TRACTOR WON'T CLIMB A HILL. TRANS MAKES GRINDING SKREECHING SOUND. ALSO TAKES OFF SLOWLY FROM STOP. HAVE PURGED TRANSMISSION REPEATEDLY AND DRIVE BELT IS OK. ANY IDEAS AS TO WHATS WRONG?
    President:
  • 1,450 Answers
Is it hydrostatic drive? if so you probably need to change filter and fluid
Posted on Oct 01, 2008
  • 2 more comments
  • TripleTauto
    TripleTauto Oct 01, 2008
    i see it is an automatic. if it is low in fluid and or the filter is clogged it will cause your problem.
  • TripleTauto
    i was referring to the hydraulic fluid and filter.
    I had a different style unit and it was growling and would barely move turned out the filter was stopped up so it could not pump fluid.
    I am not sure about your mower if it has filter or not. the trans has to have somewhere to put oil in.
    if it is indeed gears grinding then the unit will have to come apart
  • TripleTauto
    there is also an update about replacing the traction/drive spring with a 2008 model
  • TripleTauto
    It is the thick black spring that is connected to the idler plate and the deck lift rod
    I see it says it is a sealed unit but there has to be some way to check or add fluid.
  • 19,396 Answers
Check trasmission fluid first, if Fluid is ok you may need to replace the transmission box, some of the gears is defective, and gears are not sinchronized anymore.
    Master:
  • 479 Answers
Try to service the old transmisson it may work.but if that does not work just replace the transmisson.
purchasing a new hydrostatic transmission is much advisable as its definately the problem of hydrostatic transmission with out any doubt .but i hope servicing the old works.
John Deere 430 lawn tractor hydrostatic transmission will not work in forward or reverse even with no weight on the axle. New filter and oil did not fix. What should I check next?
Some have a procedure for "burping" air from the hydraulic system. Changing engine oil and filter won't affect it- independent system.
Apr 02, 2017 | John Deere Garden
John deere 425 transmission pushing fluid out of vent on top of transmission. PUmp making a whining noise
You have a fluid overheat condition here, so something is wrong inside the transmission that is causing this.
Feb 22, 2017 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
John Deere D105 Lawn Tractor will not go forward
does it go in reverse ??? if no, suspect the belt, or did you have the wheels off of it recently ??? if yes then still suspect the belt or a bad transmission
Nov 23, 2013 | John Deere Garden
What's your problem? wont move forward or back
Go to youtube . Type in your make and model/ forward and reverse will not engage. Should be helpful.
Dec 14, 2017 | John Deere 22HP Hydrostatic 42" Riding...
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
I just got this broke down John Deere 245 with the 14 hp Kawasaki. Everything works but one major problem it doesn't move. When I move the transmission to forward or reverse I have no movement. I have...
well if the drive belt is working, that is it turns the large pulley on top of the transmission, then most likely you have a bad transmission. the last owner found out that it will cost more to get another transmission than the tractor is worth. there is a small stamping along the bottom center of the transmission, will tell you the make and model and you can start searching for a NOS one on ebay or a used one at a lawn mower junkyard.
Nov 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Sep 29, 2009 | Garden
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Garden Logo
3,237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
