Question about Hampton Bay 24750 Huntington III Ceiling Fan
Need a new blade
I need a new Blade for my Huntington III do you know were i can get one
  • 16 Answers
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Posted on Jan 21, 2009
  • 76 Answers
Lowes or home depot sets of 4 and five
Posted on Oct 28, 2008
My Hampton Bay Huntington III fan has stopped working. I can pull the chain and feel the motor vibration like it has power but he blades won't turn. I have tried spinning them by hand with no
Most likely fan motor winding(s) are burned open. You may need a new motor.
Nov 06, 2014 | Dryers
Extension pole sways back and forth while the fan is on
One or more blades is out of line. Get a ruler or a stick and mark the distance from the tip of one blade to the ceiling. Hold the stick in place and carefully rotate the fan until the next blade is near the stick. Do this until you have all four marks on the stick. It is important to try not to alter the position of the extension pole in between blades. Now you will find that one or more blades are at different heights. Carefully bend the worst blade until it is closer to the rest. If teh blade holders are cast, this may not be possible and you may have to pack the blade angle with washers or cardboard until they are right.
If by some chance they are all close, then it may be the "attack angle" of one blade. This is harder tot detect but sometime you can pick which balde by eye and adjust by trial and error until it is better.
Nov 07, 2010 | Hampton Bay 24750 Huntington III Ceiling...
My fan do I fix
switch one blade to another, if that does not work you can measure from the ceiling down to each blade on fan, the blades that are off. you have to remove and shim that blade up or down, put the shim or washer were blades hook on to fan. when the blades are level then it should be ok!! good-luck!
Oct 23, 2010 | Hampton Bay 24750 Huntington III Ceiling...
My ceiling fan is wobbling and it used to be steady. It appears to be off balance and I don't know how to fix it. Do you have any suggestions
First loosen the canopy cover and make sure that all the mounting screws are securely tightened, and that the fan is connected securely to the mounteing plate.
After tighteneng all that if the fan is still unsteady, completely clean all the blade surfaces. Then using clothes pins , start adding the clothes pips , like 2 or 3 at a time to a blade about 3/4 out from the center. Try adding to each blade until you compensate for some of the wobbling. By trial and error, increase the weight, shift the position of the clothes pins, and change the weight to different blades to get the best performance. Then when you are satisfied with the correction, tape coins to the top of the blade to replace the clothes pins. again with trial and error, ballance the weight to get the best condition.
Jun 12, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Model # yg2047b. I had this fan installed in June, worked fine,now it hums..what could the problem be?
If the fan does not spin and the motor hums, you have a stuck rotor. It may be due to bushing/bearing alignment problem or a lubrication problem.
Try to spin the fan blade manually. It should turn freely, otherwise the rotor is stuck. Remove fan blade and put few drops of lubricating oil on the bushings/bearings and manually turn the shaft to free it up. Alignment of shaft and bushings/bearings must be after lubrication is done and the rotor is still stuck. Move the shaft up and down and side to side until it smoothly spin when manually turned.
Aug 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Need replacement blades for a Hampton Bay Huntington III 52 in ceiling fan with 5 blades. Where to find them?
Although we do deal with Hampton Bay fans ourselves, here's a link to someone who does:Contact Mike Evans
Phone: 979-553-3260
Ceiling Fan Parts & Service
Jul 22, 2009 | Hampton Bay 24750 Huntington III Ceiling...
CFL bulbs for fan fixture
I had a simple question and you wanted me to pay you to answer it.
I am still hoping to get a CFL lightbulb with socket size E17 to provide more light for my kitchen, but you won't help.
Screw you all.
Oct 06, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Broken fan blade
you can goto a habitat for humanity store they would have full or seperate blades or heck even a junker fan here with your blades for cheap or a thrift store but if your looking for correct size blades the most reliable place ive been able to order from is true value store
Jun 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
262 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
