Question about Dell Inspiron 6000 Notebook
Battery The battery has been worthless for a long time but I have been using the computer with the power adapter. Now the computer does not work even hooked to the adapter? I would think the computer should work when pluged into to the power adapter regardless of the battery status. I am assuming that I just need to buy a new battery. The battery is a 53wh 11.1v, type d56318. This doess not match what the dell web site said the batter for the computer should be. Does anyone know if this is in fact the problem and what is the correct replacement battery?
  • 84 Answers
Yup a bad battery in a Dell will cause this issue
A few systems will let you run with no battry ... IBM for one
unfortune that your dell meeds to at least pass voltage ...
do buy a battery to keep a going
LB
Posted on Oct 01, 2008
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Lenovo Y550 has been sitting without being used for many months. I tried to power up today. It starts, the disk drive symbol flashes for a second or two, and then it stops. I've tried removing the...
If it works with the AC cord plugged in and not on battery, then you have a dead battery. Even when plugging in the battery it's going to try and charge the battery and THEN provide the computer with power. Get a new battery.
Oct 25, 2013 | Lenovo Y550 Notebook
Benq joybook lite
Batteries only have a useful life and once it is used up they have to be replaced.
If you can get on the laptop and work without any problems using your AC Adapter and Power Cord then the battery is definitely dead and needs to be replaced.
If you have problems using your computer using the AC Adapter and Power Cord then either your Power Cord is Bad or the DC Power Jack where the power cord plugs into the computer is bad. If either of these two is bad they will not charge a Good Battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 04, 2012 | Acer Aspire Computers & Internet
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
I have connected my nanomax ipod to the computer and it is not charging.how should i charge it?
Good morning, afternoon, evening or night; whatever time you are viewing this solution post. Thank you for choosing FixYa to solve your problem. So you have connected your Nanomax iPod to the computer and it's not charging like it's supposed to, and you want to know how you should charge it properly? There are two ways you can charge the battery - charging via your Dock Connector to USB Cable, or the Apple USB Power Adapter (which is sold separately). Here are the step by step instructions to charging your and Nanomax.
Using the Dock Connector to USB Cable
  1. Using your Dock Connector to USB Cable, plug the dock connector end to your iPod and plug the USB end to your computer. Make sure the computer you are using has a USB 2.0 port (check your computer's technical specifications to see if it's USB 2.0 certified). Most USB ports on the keyboards of laptops do not provide enough power to perform charging activities. If you have a Docking Station, plug the docking connector into the station and placed the iPod in the station as well.
  2. Make sure your computer is fully awake and not asleep (meaning in sleep mode).
  3. A fully charged battery takes 3 hours to complete. An 80% charged battery takes an hour and 30 minutes. The battery is charging when it shows the charging icon (a battery not fully shaded in green, with a lightning bolt).The battery is done charging when the "fully charged" icon shows (a green-shaded battery with a 2-prong plug showing).
  4. When you are done, disconnect the cable from your computer.
Using the Apple USB Power Adapter
  1. Connect the Alternating Current (AC) Plug Adapter with the power adapter (if connected already, skip this step).
  2. Using your Dock Connector to USB Cable, connect the dock connector end to your iPod and the USB end to the power adapter.
  3. Plug the power adapter into a polarized wall outlet or surge protector outlet.
I think you connected everything correctly, but the USB port on your computer did not have enough power to charge your battery. If that's the case, you will have to find a computer that has a USB 2.0 port on it (like a desktop PC or MAC, or a car adapter charging device) and connect to it, or use the USB Power Adapter (sold seperately). I think this pretty much answers your question. I hope this benefits you the best way possible. Once again, thank you for choosing Fixya as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time you are viewing this, and visit us again the next you need assistance troubleshooting.
Apr 27, 2011 | Audio Players & Recorders
It worked, then it only let me use it only for about 5 minutes then turned off again. I did the procedure again, and it only woke up for under a minute. Does this mean I need to replace the battery? Why...
Hello luzsavinon, the "Computer" more than likely "Turn-off,
because of the "Power Savers' [Mode] that it is in.
The 'actual way' it should work; is when you are using the Battery; the 'Power' should "Conserve Energy."
But because you are using 'both' the Battery and "Power Adapter!"
The "Power Saver Mode," is using the 'least power.' this being the "Battery!
Do the following:
  • "Log-off and "shut Down the Computer,"
  • "Unplug from the Power Outlet."
  • Next, "remove" the Battery.
  • Plug the Power Adapter, 'back' into the Power Outlet.
  • Restart the Computer.
!Warning: It is "Unsafe to use 'both' Power Adapter and Battery at the 'same' time."
  • "You can "Overcharging the Battery," causing 'Damage" to the "Battery, and or Computer!"
!Important:Use 'only' the Battery or Power Adapter 'separately.' If you are still experiencing the same problem?
  • Go to the "Start Menu."
  • Type in the Start Search [box]: Power Options.
  • When the 'window' opens!
  • 'View', in the {left} Task area which best describes: "Choose when the Computer Sleep!"
"Please let me know if you 'need' further assistance, or the 'solution' helped? "By posting a 'Comment" or 'Rating' the solution. Thank you; your 'response' is important to me!"
paul7of9
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Shot down of laptop
It can be two things. One is the adapter for the power cord in your computer has been damaged and may not fully operate or your power supply has a fault it in somewhere. Test the adapter in your laptop with another similar power supply and if it works you know its the current power supply you have, if not its the adapter and it needs to be replaced and sometimes that can mean a whole new motherboard depending on what brand and model laptop you use.
Hope This Helps
Nov 20, 2008 | HP Pavilion dv4000 Notebook
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Laptop will not power up with Adapter
It sounds like there is a problem with your motherboard. You would have to take it someplace to run diagnostics on it. It may be time for a new laptop
Apr 14, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Dell Inspiron 6000 Notebook Logo
27 people viewed this question
Alun Cox
