Question about Garden
The front wheels on my lawn mower have locked
While mowing my lawn (Craftsman 22" 6.75 HP push mower), the power propelled front wheels would begin to fail as I would stop, turn and lean the front wheels back on the ground before starting to push. When that occurred, I would dis-engage the power drive and re-engage it, and it would seemingly resolve the issue. After about 3 or 4 times doing this, the front wheels failed again, this time on a straight-away, and disengaging and re-engaging didn't fix it. The front wheels now will not roll without significant pressure applied. Assuming that this is a failed power drive, is there a way I can "unlock" the wheels such that they roll freely? Otherwise, is there something I can do to fix the power drive? Thanks for your help...
  • Anonymous Mar 12, 2014
    If you turn the steering wheel for one wheel to get straight then the other wheel is turned to the outside
  • 48 Answers
On yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Posted on Oct 21, 2008
    Problem Solver:
  • 4 Answers
I had this same issue. In my case, the sheild that keeps the dirt out of the gears in the wheel has gotten broke and the gears filled with junk and jammed the wheels. I just have to take the wheels off and blow the junk off the gears.
Posted on Jun 07, 2009
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
The mower is not pulling.
Check if your belt on. The manual states taking you front wheels apart. Remove grass wrapped around parts. Grass to high. Raise platform up.
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
675 series self-propelled - Front right wheel bearing assembly separated, wheel wobbles
I would take it back to the store and ask for warranty repairs since it is so new. That's ridiculous. If that doesn't work, try Sears Parts on-line or on the phone. They are better than most other manufactures.
Oct 12, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Self propelled stops working well mowing, I
turn it off,let the drive handle go,pull mower backwards.does it lock the back wheels?if you push it forward,can you hear a clicking noise from the wheels?you should do.lift mower,spin back wheel,should either lock,or click,depending which way you spin it.they have spring loaded pawls that drive the wheel.usually easy to fix.usually dirt,or too much grease.take wheels off,have a look
Jul 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Ned a rear wheel replaced on self-propelled push
look on craftsmans website and see it they have the wheel or look on partstree.com and they might have it!! have fun!! :)
Apr 01, 2010 | Garden
Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Oct 01, 2009 | Garden
Garden Logo
1,536 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
