Question about ASUS WL-500W Router (WL500W)
Problem open a series of ports ASUS WL-500W
I have a problem opening a series of ports. (ex 7777-8000)
I read at www.portforward.com that i just add in port list 7777-8000, but when i try to do that it just says "7777 is an invalid port number"
If i try to open just one port it works, but i don't want to add like 100 ports one at a time.
How do i open a series of ports?
  • MrAndersson Oct 06, 2008
    I think that worked, thank you.
  • 33 Answers
Hello!
You should try to add a port range like this 7777:8000
Hope this helps!
Posted on Oct 02, 2008
Asus customer support
Can you please share with us your Asus broadband router model number and your Windows version so that we can suggest a solution specific to your model? In the meanwhile, you can refer to the following link to try securing your Asus router wifi network.
http://portforward.com/english/routers/wireless/Asus/WL-520G/xwireless.htm
(Important: As these are third-party websites, we recommend you to update your security software thoroughly before opening the links. Also, avoid opening the links if your system/ security software pops-up security warning while loading the websites).
GuruAid.com
Jul 06, 2014 | Computers & Internet
How to set up the wl-330ge as a repeater?
What the instructions don't clearly explain is you must plug the WL-330gE into a device that has both a wireless connection and an active ethernet port. If the ethrnet port is active you should see two small lights on either side of the ethernet port on your device after the .WL-330gE is plugged in Once that's done you can run the detection software and it should find the device. Select configure and a browser will open and you'll be taken to the ASUS configuration website. Log in using the user name and password in the startup guide. The configuration page my open up in Chinese language, if so select the drop down at the upper right corner of the screen and pick the first item in the list which is English. Select the tab which matches the configuration you need and follow the instructions. Hope this helps.
Vaughn C.
Jun 23, 2009 | ASUS WL-330GE 802.11b/g Wireless Access...
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Asus WL-500W USB printer - Can't add printer
Fixed it, remember to install the vista driver for your harddisk, then select the port of the ip to the wireless devide, then it should work, you can check in the wireless web setup that the printer is located, under System.
May 12, 2008 | ASUS WL-500W Router (WL500W)
ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Mar 27, 2008 | ASUS WL-500W Router (WL500W)
Unable to input a HYPHEN in portrange
With this particular router you will need to treat the port range field as the port field. You will just have to forward single ports at a time. Which will be fine. In case you need more reference see the link below.
http://www.portforward.com/english/routers/port_forwarding/Asus/WL-520G/WL-520Gindex.htm
Hope this helps!
Jan 10, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Open Questions:
ASUS WL-500W Router (WL500W) Logo
144 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
