Question about ASUS A8N-SLI Deluxe Motherboard
Asus a8n-sli deluxe long beeps
Well the motherboard will not go through post, i get a long beep, followed by another long beep....the GPU is fine, the memory controller is the only thing i can think of.....any ideas?
  • newrevo Oct 01, 2008
    yeah the thing is it was working fine for 2 years now and this happens out of no where....and as long as i know the chips are compatible, we even tried other ram and still the same thing.....??
    thank you though
  • 124 Answers
Are you absolutely certain that your chip is compatible with your motherboard?
Posted on Oct 01, 2008
  • Chris Brewer Oct 10, 2008
    Did my solution help? Please rate my answer. I hope that I helped. Thanks!!!
What are its BIOS Beep code details?
The codes are different for each motherboard. Find yours here:
May 16, 2012 | ASUS A8N-SLI Deluxe Motherboard
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
A8n-sli deluxe one long beep and end. Please help. Thanks
Hi krzysio007! If you hear a beep once you start the system and it does not go away, this might be the CPU fan not functioning correctly. Try disconnecting the fan, cleaning the connectors and then plugging it back again. I have a similar problem with a motherboard just like yours, and usually the beep goes away after it boots into Windows. Since this motherboard has an Award BIOS installed on it try these error codes: Here. Hope this helps you with the problem!
Feb 28, 2011 | ASUS A8N-SLI Deluxe Motherboard
No Signal, No Beep, No POST
thing is that *********** board goes damage its able to repair so repair it or buy a newmotherboard
May 11, 2010 | ASUS A8N-SLI Deluxe Motherboard
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
Two long beeps when cutting on
Look up all your beep codes here
Also a great FAQ on your motherboard here
Jan 21, 2010 | ASUS A8N-SLI Deluxe Motherboard
IBM 8650 continuous long single beeps
check your power suply,smps,and also check your motherbord dont touch the cabinet.
also check your processor case and clean it.
Mar 31, 2008 | ASUS A8N-SLI Deluxe Motherboard
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Mar 14, 2008 | ASUS A8N-SLI Deluxe Motherboard
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes:
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first:
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
