Question about Hitachi CP-X1250 Multimedia Projector
Bulb Instrucion on how to change the bulb for the HTACHI CP-x1250 Multimedia
  • 10,594 Answers
Instructions How to change Lamp in Hitach CP-X1250 are available on User Manual page-38
Please confirm do you have User Manual?
Posted on Oct 01, 2008
Hitachi CP-X275 projector failure
check the bulb is fully seated and connected. otherwise it could be the bulb firing board or connections to the bulb.
Dec 10, 2012 | Hitachi CP-X275 Multimedia Projector
Can LED bulbs be used as its lamp alternative ? if so, how much power would be used ?
No direct replacement as far as I know, wish there was. there is a starting circuit to fire up and run and monitor the bulb which is specific to the mercury bulbs, you would have to change more than just the bulb.
Nov 04, 2012 | Hitachi CP-X345 Multimedia Projector
The filter needs replacing. Do you sell replacement filters for model CP-X1250?
Take the filter to the local electronics repair shop and ask them for some filter material like the one in the unit. Then cut it to size to fit like the old one.
Mar 25, 2011 | Hitachi CP-X1250 Multimedia Projector
I cant see any light from the projector bulb. it is like it is trying to boot up but does not start, perhaps the bulb is gone it is a CP X327 type
what are the state of the leds on the top cover as it tries to start up, and what finally do the leds indicate when it gives up trying
Mar 06, 2011 | Hitachi CP-X327 Multimedia Projector
Is the only difference between at CP-X1200 and CP-X1250 the bulb, or is the ballast circuit different too? Just thinking how easily I could boost the brightness from 3500 to 4500 lumens.
Model: CP-X1200 ( Lamp)
Part#: DT00591
Lamp Type: UHB
Wattage: 275 Watts
Lamp Hours: 2000 Hours
Model: CP-X1250 ( Lamp)
Part#: DT00601
Lamp Type: UHB
Wattage: 310 Watts
I'm not sure but I would think the same ballast board is used, and the trimpots adjustments set in the factory.
If you fiddle with it, you may not be able to get the tube to strike on startup, or worse you can explode the lamp.
Also the extra heat generated may degrade the optics and LCD panels.not mention melting the housing.
Better to leave well alone.
Feb 18, 2011 | Hitachi CP-X1200 Multimedia Projector
Hitachi CP-X1250 MULTIMEDIA PROJECTOR - MENU> MAIN> BRIGHT and CONTRAST are not active. BRIGHT and CONTRAST How to enable? I can not make adjustment.
hi,
Go to menu and then select main. then select reset and execute it.After that try to adjust the brightness and contrast.
Remember on thing, in some projectors the brightens and contrast will be active when there is video signal. also try that.
ok
Jan 26, 2011 | Hitachi CP-X1250 Multimedia Projector
My hitachi cp-s235 projector has a blueish hue on the left side. how do i fix it, it is a brand new bulb
i think it is mothing to do with the bulb it is the stup of the 3 color frame inside ,or iternal dirt ....need profesional store ....
Aug 30, 2009 | Hitachi CP-S235 Multimedia Projector
Hitachi CP-X1250 Multimedia Projector Logo
538 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
