Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator not working
I have a kenmore refrigerator (side by side). the freezer section has a lot of ice build up at the back wall and the refrigerator side is not cooling as much. i've had to throw $200 worth of groceries alreayd and have a baby coming in the next 2 weeks. can someone advise if its time to replace the fridge or should i call a technician to have it checked out?
we cleaned the vents below the fridge but, that is still not helping. this is probably the third or the fourth time the problem has come back.
Please respond to me as soon as possible. I need help!!
  • brient6 Oct 13, 2008
    Excessive ice build up on the freezer and fridge not cold enough
  • 120 Answers
You have a defrost problem a tech will charge you between 100 to 200 to fix it unles you do a little research and repl the timer and bimetal but i will lean more to the bimetal that controls the heater but definetly is defrost issue easy fix but if you dont know how my number is on the tech list
Posted on Oct 17, 2008
Kenmore elite refrigerator
where is the ice,is it on the food and shelves or is it on the back inside wall of the freezer?if it's on the back inside wall of the freezer you have a defrost problem,bad defrost thermostat,heater,timer or board depending on your model number,if it's on the shelves,door and food packages warm air is getting into the freezer somehow either from the door not closing or the door was left open,could have a bad gasket on the door,the ice chute door could be broke and not closing.let me know what you find and the picture shows a side by side but i'll need the model number too,if it's a side by side or freezer on the bottom the model number should be in the fridge section,on the right hand wall up near the ceiling,if the freezer is on top the number should be on the left side wall in the fridge section up near the ceiling.but with this hot wheather we're having if the door was left open this will happen,you can shut down the machine or unplug it,remove the food from the freezer and melt the ice with a hair dryer,don't do this with the machine running because the hot air will cause the same problem,after the ice is melted you can put the food back in and restart it.
Jul 20, 2013 | Refrigerators
Ice build up on back wall of freezer
You need to replace the heating elements and defrost timer relay. Had same thing as you 6 months ago. The lower one is probaly blown but replace all 3 parts or youll continue to have problems.
Jun 11, 2009 | Kenmore 53642 / 53644 Side by Side...
The back wall of the freezer section have an ice build up
the deforsst motor or fan is most likely froze up let your frezzer fridge defrost for ATLEAST 24 hours which i know is a pain being that u will need to open the doors and turn it off for the whole time but it might solve your problem .. it is very common.
Jun 03, 2009 | Refrigerators
Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
I have lots of ice freezing to the back wall of the freezer side.
it may not be working or it is not set to cycle often can also check for air leaks.a constant air leak will cause a lot more ice to build up.
Mar 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Both the Freezer and the Refridgerator quit working...
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Dec 21, 2007 | Maytag MTF2156GEQ Top Freezer Refrigerator
Refrigerator not cold.
if the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Dec 19, 2007 | Maytag MSD2456G Side by Side Refrigerator
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Oct 10, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
