Palm Tungsten T5 - Multilingual Handheld
Problem for Palm Tungsten T5 - Multilingual Handheld
Contact look up
By Odud - usenet poster
Using KeyContacts, how do I perform a contact look up on the handheld?
Solution #1
posted on May 30, 2006
Not Rated)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
To quickly locate particular contacts within the KeyContacts handheld application, use the "Smart Look Up" feature. This feature allows you to specify on which fields within each contact your search will be based.
To specify the search fields used for "Smart Look Up", please do the following:
1. On the handheld, open the KeyContacts application.
2. From the KeyContacts List View screen, tap on the top left corner of the Palm screen to open the menu bar.
3. From the menu bar, tap on "Options" and tap on "Preferences".
4. From the "Preferences" screen, under the heading "Search in these fields:", tap on the any of the fields (First Name, Last Name, Company, File As) you wish KeyContacts to search and tap "OK". Note: The more choices you select the greater your search results will be expanded.
To search for the desired contacts, enter one or more letters into the Smart Look Up field (located on the bottom of the KeyContacts List View screen) and all the contacts containing the entered character(s) will be displayed in the contacts list. If the character you type is not found in the search fields you chose, the handheld will beep and the letter you entered will disappear. In the example below, the letter "J" was entered and the search results are displayed.
Was this helpful?
Yes
No
Popular Solutions for Palm Tungsten T5 -
Questions and Unsolved Problems for Palm Tungsten T5 -
Do you recommend Palm Tungsten T5 - Multilingual Handheld?
Answer
Answer
The file transfer system is not responding. It can't find my device.
Answer
Versa mail will not sync with gmail on a Palm T5 - gets error message about the SSL. Is there a mail... (More)
Answer
Fatal Alert MemoryMgr.c, Line:3752 Null Handle Reset The above appears when I try to HotSync. I have... (More)
Answer
The message is on the t5 unit it self. down loaded up date to the palm desktop and seems to be okay.... (More)
Answer
MemoryMgr.c,Line:3752,NULL handle
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Palm Tungsten T5 -...:
Top PDA Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
