Question about Logitech Cordless Desktop EX110 Keyboard/Mouse
Cannot get keyboard to work.
Had to take my computer in for some updates. My keyboard isn't working now. I tried to set it up again, but I don't have the purple connector. Is there any way for me to do this without it?
    President:
  • 8,637 Answers
If it were me, I'd go back where they did the updates and have them get the Keyboard working for you. Bud
Posted on Jan 19, 2009
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
Malfunctioning new aluminum keyboard x 2!
are you sure its a issue with the keyboard, I would suggest trying these two keyboards on another system to see if they really are at fault.
Thanks,
Ekse
Aug 28, 2008 | Apple M9034LL/A Keyboard
Toshiba Satellite.C655.enable.space.bar
Hook a external keyboard, if okay! problem with the laptop keyboard. Try a system restore and bring the computer back to a earlier time before this happened, just might work. The keyboard can be disabled from the bios setting I don't see how it can be done any other way.
Mar 17, 2012 | Toshiba Satellite C655-S5140 Notebook
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Display don't comes back after LCD goes to Standby. Moving the mouse or pressing keys in keyboard don't work at all to return the display, but the tasks(if downloading or copying etc) are...
have you tried pressing the F4 key or the shift key after stanby mode
you might have to uninstall your keyboard restart your computer then reinstall it
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
click start control panel administration tools computer management device manager scroll to keyboards you might see a yellow exclamation or question mark or red x you will need to update driver right click to update driver
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
if your computer came with a motherboard disk the drivers could be on it
or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
or you could restart you computer you will see on the scree to press a certain key to enter set uppress and hold that key to enter BIOS you can load failsafe or optimised defaults
hope this helps
Aug 13, 2011 | Intel DG45ID Motherboard
Hi I have an Intel Atom D425 GMA3150 1.8GHz 160gb HDD 1GB DDR3 netbook. And the touchpad isn't working and the keyboard kept stopping and you have to restart the machine for it to work again. But no...
Hello h_bayley29,
First "restart the computer, this will "clear all the attempts to
change the settings.
If the type of Computer your using do not show the
{Pictures} that look the same?
"Just follow these instructions for the "Touchpad."
"In the (right area), select to open the Control Panel.
Next in the [Hardware and Sound] category.
"Choose the "Mouse" paul7of9_109.jpg 'applet.'
Next, click on the"Device Settings" in the (Devices) block.
"Highlight" the item you want to (Enable) this being the "Pointer Device."
Click on the [Enable] button.
Be sure to (Click) on the "Apply, and OK buttons" "You may need to "Update Drivers?"
Next in the "Mouse Properties" (window).
Open the "Properties,"
Now, open the [Driver] by [2x clicking] on it."
If the, Update Driver (block) is not "Grayed-out?"
Click to "Update Driver", and click the (OK) button.
"To Manually" Install Driver
Select to "Update Driver."
Next, select: ("Browse my computer for driver software").
Now, choose: ("Let me pick from a list...").
"Open the "Device Setting:
Click on the "Settings" button.
"Try out some of the "Items listed" ->->
*Tapping, *Virtual Scrolling...
"You must click on the "Apply" button after each change
This should fix the Touchpad?
If you need more assistance, please write a 'comment.'
"Best Regards"
Jul 12, 2011 | Computers & Internet
Cannot access safe mode via F8 Believe keyboard is not set up correctly.After loss of power cannot control windows screen to select diff options for start
Do you have a mouse if you do you can still access different options in windows start using only a mouse..Try to clean the keys of your keyboard by using a dry paint brush to remove dust that can affect the keys to function don't open the keyboard by unscrewing it because keyboard key is really difficult to return again after opening it and do something with the keys. If still the problem isn't solve I will advice you to buy a new keyboard for you to use your computer without a problem..
Jul 04, 2011 | Computers & Internet
Sustain pedal doesn't work any more - maybe it isn't the fault of the pedal? I don't want to order a new one if the problem is in the keyboard. I'm sorry, I just lent it to summer guests...
take it into a music store and try a pedal there in store. If it works, buy the new pedal and charge the guests. If it does not work, you know it's th TS input on the keyboard
May 20, 2011 | Casio WK110 Portable Keyboard
Many charcters in the keyboard doesnt work in dell xps m1330
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver
if your computer came with a motherboard disc the drivers could be on it
hope this helps
don
Feb 25, 2011 | Dell (E210882) Motherboard
Microsoft wireless keyboard stopped working (mouse still works)
I have been fighting this same problem for about 5 months.
I have the Wireless Optical Desktop 3.0 (Wireless Comfort Keyboard & Wireless Optical Mouse 2.0). Three or four times a week it stops working at random intervals. The driver DLLs simply disappear. I can see this by going to Control Panel -> Keyboard Properties -> Hardware -> Properties -> Driver -> Driver Details. The two dll files are there when it works and the dll files are gone when it stops, gone, no drivers at all. An old PS2 will still work in a pinch.
I wonder if the problem may be caused by my Windows Live OneCare or by a Windows Update that keeps reinstalling itself and failing. Alternatively, could it be that some malware is trying to gain control of the PC?
Reinstalling the software & rebooting fixes the problem --for about a day.
Jan 06, 2008 | Microsoft Wireless Optical Desktop Comfort...
Logitech Cordless Desktop EX110 Keyboard/Mouse Logo
75 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
