Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Pentium D problem
I got a new Pentium D 2.8 Possessor socket 775 but when I put it into the board it booted, overheated, then shut down.
  • oiliaN Oct 02, 2008
    But I mean it instantly overheated and shut down, it wasn't that it worked for a while and shut down it was like 10 seconds from boot to overheat to shutdown. It didn't even get out of the Bios Post message.
  • oiliaN Oct 08, 2008
    Im sure, I touched the CPU and got burned. I was putting it into my motherboard to test it for sale.
Are you sure it overheated or did the power kick off and your fans stopped spining. Sometimes your mobo can shortout on the backside from screws that are too tight or are incorect in length.
Posted on Oct 07, 2008
    President:
  • 2,351 Answers
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Posted on Oct 01, 2008
  • Mike Peluso
    Mike Peluso Oct 02, 2008
    Please remove the CPU from the motherboard. Clean it with alcohol & blow it dry. Turn it over & check the copper pins. Look for bent or broken pins. With the pins facing up, bring thre CPU to eye level & look across the pins. (This makes it eayser to catch a bent pin). If everything looks good. Return it to where you got it or to the maker of the CPU. Most CPU's come with a three year warranty. Please check all your internal connections & reseat your memory. Make sure the fan is running in your power supply. Blow it out with canned air. Double check all power connections.
  • Mike Peluso
    Mike Peluso Oct 08, 2008
    If you tried all of the above & your CPU is hot enough to burn you. Return it. As mentioned it should not get that hot if thermal grease is applied & CPU fan is running. The average CPU fan runs at 2000-3000Rpm.
    You can call Asus at 1-812-282-2787 tech service.
Installed pentium d 940 duel core. Will not boot. need solution
Assuming the new processor is compatible with your MB there are several things to check. Do you have jumpers on your MB to identify different processors? Can you get to the BIOS with the new chip installed. There are several settings in there that could affect your boot process. Lastly, is your BIOS compatible with the new processor?
Feb 20, 2013 | Intel Pentium D 940 32GHz 800MHz 2x2MB...
Ms 7529
Hello here are the supported cpu list for your mainboard:
http://www.msi.com/product/mb/G31M3-F-V2--3-Audio-Ports-.html#/?div=CPUSupport
You maybe have to upgrade the bios to support the new cpu.
May 25, 2012 | Intel Motherboard
Does dual core processor support Foxconn P9657AA-8EKRS2H mother board
The Foxconn P9657AA-8EKRS2H motherboard has a LGA 775 Socket. It will support Intel Core 2 Quad, Core 2 Extreme, and Core 2 Duo processors with an FSB of 1066 (800MHz). Thus is should support the dual core 775 processors. (Some Pentium 4, Pentium D and Celeron D CPUs may also be compatible with the board.)
I hope this helps.
May 06, 2012 | Foxconn P9657AA-8EKRS2H (6938279104065)...
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Mother board 533 prescoot how the accpet ram and processer
This motherboard supports DDR2-800/667/533 Memory and any socket LGA775 CPU such as Intel Core 2 Quad, Core 2 Extreme, Core 2 Duo, Pentium XE, Pentium D, Pentium 4, and Celeron LGA-775 CPUs
Feb 01, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
Nobody has a list of cpu's that will work with this mobo. Biostar P4M800-M7A Ver. 7.0. It was sold as compatible with dual core cpu's, but no-one has a list of which intel 775 dual cores. Did New Egg lie?...
P4TAW Extreme 1.0 925X Socket 775 Pentium 4 3.6GHz I915P-A7 1.0 915P Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I915G-M7 1.0 915G Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I86PE-A7 1.0 865PE Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I865G-M7 1.0 865G Socket 775 Pentium 4 3.6GHz Celeron D 3.06GHz N4SIE-A7 1.0 NF4 SLI Intel Ed. Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz P4M80-M7 1.0 P4M800 Socket 775 Pentium 4 3.6GHz Celeron D 3.06GHz
Dec 08, 2009 | Biostar P4M800-M7A Motherboard
Need a prossesor for motherboard
You can also use any other intel 775 socket processor as well. The dual cores are at the top of the list for performance that are compatible with that board, but if you're looking for a cheaper solution, I have that board with a 3GHz pentium 4 and it runs great. Here's a list of all the processors you can use.
Intel Pentium 4 (2.66 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Intel Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 2.80 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel 'Core' Celeron (1.60 - 2.40 GHz)
Aug 03, 2009 | Dell (E210882) Motherboard
Biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
Jul 07, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
296 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
