Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refrigerator now cooling
Frigidaire refrigerator side by side ,evaportor frost up ,replaced the cold control/auto defrost control ,still have the same problem. can you help me.
  • Anonymous Nov 08, 2008
    REFRIGERATOR SIDE NOT GETTING COOL, BUT FREEZER APPEAR TO BE OK
  • 958 Answers
Check the defrost heater, could be broken, another thing to check is the bi-metal. it should have continuity if frozen and open resistance if thawed.
tnx 4 using fixya,
drcool
Posted on Oct 01, 2008
Frs26zgh-frigidaire/ gallery,frig is'nt cooling at all- freezer is cold,but not freezing.
Wow I hate to see that because I have one. You must have a defrost issue. Look on the backside of the freezer for noticable frost. That is an indication of something in the defrost system failing. Defrost system consists of a defrost heater, a defrost heater termination thermostat, and a defrost control. The most likely suspect is the defrost heater termination thermostat. It's job is to shut down the heater when the area is warmed enough to melt frost on the evaporation coils. I fixed one today with a defrost problem just like yours
Feb 07, 2013 | Frigidaire FRS26R4A Side by Side...
Refridgerator side is not cooling and freezer is wroking fine
1st i must get you to look for some symptoms look on back wall (inside) of freezer. Is there "sno-cone" type frost? yes? defrost problem. heater,defrost thermostat or defrost timer or adaptive defrost control. no? is fan running? is evaporator coil cold ,frosty? no fan but cold frosty coil(that's frosty but not frosted up) then bad fan motor probably. you need volt meter,and know how to use it. otherwise call a tek.
Sep 25, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frost free quits getting cold and inside freezer under back wall panel totally freezes up and has to be defrosted before it will get cold again.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 23, 2011 | Frigidaire FRS26R4C Side by Side...
Not cooling on fresh food side coil frosted up in lower freezer at back
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 27, 2011 | Frigidaire Refrigerators
Freezer building up with frost top and sides.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 11, 2010 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Side by side frig
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
What if both sides of the refrigerator is not getting cold?And the back of the freezer side has frost.
Defrost problem. Either the defrost thermostat, defrost heater or defrost control board needs replacement. The defrost heater has to have continuity. The defrost thermostat has to have about 0 Ohms while it's cold. If both test out ok - replace defrost control board.
Part locations: Defrost heater and thermostat: under your frosted cover; control board - left upper corner of fresh food section, under the damper cover, in the middle.
Part numbers:
240554502 - control board
5303918255 - defrost heater kit
Can't find the part number for the defrost thermostat
Oct 17, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer cool but not freezing
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models they don't have the timer but an electronic device which replaces the timer.
Jun 30, 2009 | Frigidaire FRT21S6A Top Freezer...
The Frigidaire Gallery freezer has ice build up restricting air flow
#1. DEFROST TIMER stuck or defective. Not allowing DEFROST CYCLE to occur. Most probable.
#2. THERMOSTAT (cold control) has gone bad.
#3. CIRCULATING FAN. It pulls air from the FREEZER side into the REFRIGERATED side.
#4. and lowest in probability. LOW (leaking) coolant charge.
Mar 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
