Epson TM-L60II prints extra blank line after => 256 bytes of data
We print labels on TM-L60III, 56x49 Thermal roll, punch holes every 52mm.
All lines are padded to 40 chars each using Font 2
Problem:
Using standard mode, printer prints extra blank line after 6th line?
6 x 40 = 240 bytes + 6xLF =246 bytes total in printer buffer.
In Epson Literatute I have found the following:
TM-L60II
When label paper is selected in standard mode and a paper feed amount that exceeds the
remaining print area of the label is sent, the printer feeds the label to the next print starting
position.
If this is the problem, how can it be fixed?
Regards,
Pierneefie
2 Suggested Answers
  • 320 Answers
SOURCE: Paper feed to far for labels
Adjust the paper size manually.. And Scale to a particular size.. Re-installing the driver may fix the problem... To download the driver please click on the below link or copy the URL and paste it in your web browser. Select the operating system you are using and download the driver.. Hopefully it should work....
http://www.epson.co.in/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=11&pid=115
To download the manual, click on the below link..
http://www.epson.co.in/epson/manuals/manual_download.htm?dc=1&mode=3&m=false&catid=11&pid=115
Thank you.......
Posted on Sep 30, 2008
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Jan 27, 2016 | Epson T70II - SPACE-SAVING - PUSB & USB -...
You should adjust the shutter as well to the size of the paper. Another thing is you can manually select the paper type under the printer settings. Go to Printers and Faxes > Properties of your default printer and manually select the paper type.
Sep 30, 2008 | Epson TM-L60II Thermal Printer
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Printer print blank print is blank
its a thermal printer.... which may have defects already.... when the printer prints blank its either its not heating up or the thermal mechanism is already damaged... try calling epson tech support... i think they have a warranty offer for your type of issue since its a POS system. hope this helps you with your issue. :-)
Aug 11, 2011 | Epson TM L60II Printer
Does epson tm-t88iiip have a ribbon
No. thermal printers do not use ribbons or ink cartridges. They have thermal heads that heat up and use that heat to print on the specially treated, heat sensitive paper rolls. If the printer has stopped printing, check to see if the paper is thermal and loaded correctly (shiny side facing the front when it feeds).
Jul 13, 2010 | Epson TM-T88III Thermal Printer
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Feb 24, 2009 | Epson TM-L90
Partial printing of epson TM-T88III
hi,
what you can do is to make sure that from you application you should choose the right size of paper and on the printer driver go to its printing preferences and select layout, from there you must select the roll paper.
you should be well from there..
Dec 05, 2007 | Epson TM-T88III Thermal Printer
Epson TM-T90 thermal printer
your print driver is printing in graphics mode or in reduction mode. disable print spooling, disable A4 reduction or use a faster driver like the epson advanced driver or my fav the generic text only (super fast)
Jan 30, 2007 | Epson TM T90P Label Printer
89 people viewed this question
k24674
jasbo
jasbo
