Question about Emerson RP6247S FM/Weather/AM/TV Radio
Hi,yes I bought a WeatherX. Model # tvwb534 I don't know how to set it for alarm in case of bad weather. Thank you,Sergio Treto.
I have model RMR682--Want to disable the Alarm--Please advise
The ice warning is normally only on channel 1. Just set wireless sensor to channel 2 or 3, then select that same channel to display on the base unit.
If you don't ever want to use the ice warning feature, then use channel 1 for a sensor that's situated indoors, then hope you never hear it!!!
Lee
Jan 11, 2012 | Oregon Scientific Wireless IndoorOutdoor...
How can I disarm the Alarm. I bought my 97 Cabrio used (it didn't come with the remote) The Door locks also don't work. I can't drive it because when I turn the key the alarm goes off and it...
If you don't have the remote then its pretty much useless. I have seen at Pep Boys where they sell replacements for the factory/dealer installed alarms. Or just remove the alarm completely and reconnect everything the way it was.
Without knowing what brand alarm it is a person cannot honestly answer how to disarm it as they all work differently.
If you know a brand and model you may be able to find downloadable instruction on the manufactures web site.
Sep 08, 2011 | 1997 Volkswagen Cabrio
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    I love my radio and she is always there for me..til just the other day..no warning lights..i cant get it to speak the weather ..yes even with the radio on..i can go thru the menu to get the alarm to test...
    Good morning, afternoon, evening or night; whatever time of day you're reading this. Thank you for choosing FixYa to solve your problem. Your problem is that your weather radio is not giving you updates and your warning lights are not coming on when there's a severe weather warning? I am first going to tell you to check your S.A.M.E code to make sure you have it programmed for your county. If this is correct, I don'there's anything wrong with your radio. I think, the problem might be your county/area's transmitter tower. If your county/area's transmitter tower is near one the states that have been recently attacked by tornadoes or severe weather, the transmitter tower may be out of service. You say you live in Georgia, so further in this explanation I will give you the NWS's (National Weather Service's) weather radio programming information website for your state. This will give you information for every county in your state including which transmitters are out of service if any. If the tower for your county is out of service, check a county that's near your area to see if their tower is out service. http://www.nws.noaa.gov/nwr/Maps/PHP/georgia.php gives you all the NWR stations in your state. Click on your county and it will show you a map of their broadcasting area. If it's not out of service, program that county's S.A.M.E code into your radio. You should also change the frequency channel to that same county as well.
    http://www.weather.gov/nwr/CntyCov/nwrGA.htm
    You may also want to check your antenna to make sure it's connected properly and fully extended. The National Weather Service has certain criteria that a storm must follow in order for them to sound the alarm. I assure you that the lights will come on when the radio is giving you a warning. To find out more information about this, log on to this website -http://www.nws.noaa.gov/nwr/nwrwarn.htm. I hope you get your radio back up and running as soon as possible. You can always go on the National Weather Service's website as well, to get weather updates for your area. I hope you are safe this Severe Weather Season and Thank you for choosing FixYa as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time of day you are viewing this solution.
    Apr 28, 2011 | Midland WR-100 Weather/RDS Radio
    It Will Not Turn On all it does that the backlight comes on I put it in water
    Anew one maybe great because if you've had it rather a long time then bye a new one new one because you dropped it in water then it has washed everything away
    Dec 17, 2009 | GPX WeatherX Rechargeable Portable Radio...
    The portable tv was defective before you sent to me!
    fixya doesnt sell products need to send you request to the proper party
    Apr 21, 2017 | GPX Weather X TVWB534 5 in. Portable...
    10 year old alarm chronograph
    good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
    Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
    Emerson RP6247S FM/Weather/AM/TV Radio Logo
    60 people viewed this question
    Top Emerson Audio Players & Recorders Experts
    Greg Cann
    Greg Cann
    Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
