Question about Philips Televison & Video
My phillips 42" flat screen model number 42pf7621d/10 keeps blowing the fuse in the plug usually after we have turned the tv off and its in standby mode or overnite when we sleep ive just change another one now which it blew as soon as i powered up but then changed it again and its working fine once the tv is on it can reamin on all day without blowing fuse it just seem to do this at tinitial start up
  • 10,594 Answers
What is rating of fuse in your TV like amperes and volts.
There is Thermistor in TV for degaussing the picture tube while in start up. This part requires heavy current to work for a second or two.
You can increase little bit current rating of fuse to avoid blow off.
Posted on Oct 01, 2008
Philips 42pfl3704d/f7 No power at all
its definitely the fuse. you have to go to the phillips website and type in your model number to get the right fuse. I went thru 3 different fuses and they all blew right away. phillips website sells the right ones 5 bucks each. Get it here and it will save you trouble trust me.
If nothing happens no light or sound when you plug it in to the wall it is definitely the fuse. mine was a T8AH250VP. You have to be sure to get that exact fuse. every letter exactly like that. there are a lot of similar fuses that will blow the moment u plug it in.
Hope this helps took me a month to figure this out. I was going to buy powerbaords for no reason. fixed my 42 inch phillips for under 10 dollars. couldn't be happier. Also always run your tv threw a power ack. If you plug directly to the wall your fuse will blow frequently.
Sep 23, 2012 | Philips 42PFL3704D LCD TV
My 42" flat screen phillips
I'd post TV model number first - it's on the back of the TV -and I'd also post a picture if I could.
The lines on the screen do not usually go with the "channel not available" problem and the likelyhood of you having both at the same time is , well, small.
Sep 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
Have no picture but still have sound Philips 42" Widescreen TV
you are gonna have to take this apart,lay flat on table to remove the cover.first look at the power supply board,you are looking for swollen caps(round canaster-one side is marked - in black meaning negative.this tv came with 2 versions of power supply.part numbers 272217100569 phillips or DPS-279CP A delta.if you do not see any bad caps look for a bad fuse,replace if bad.if it blows the fuse again inverter boards,part numbers 6636L-0022A and6636-0021A.all of these parts are available at shopjimmy.com,just type in model number,scroll down to find any of these parts.
Sep 24, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
My phillips 42" HD Flat screen won't turn on
I switched the power cord with the one to my desktop monitor and it worked ..i noticed the end going into the TV had some discolor to it ..I put the one from the TV into my desktop monitor ..and that worked too..must of been a shortage of power from the cord to the TV?
Jun 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
Phillips 42 inch tv
Vendor nap.jpg Part Number 310430814621 Description Stand Base
Tritronics, Inc.
(800) 638-3328
call these guys and they should be able to locate it for you or at least tell you where to get one.
Mar 18, 2009 | Philips Televison & Video
Screen keeps blinking red
check the menu and see it it hase the same issue if sone one of the main boards are bad.
May 27, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
