Question about E-Machines emachines (emachinees) CD-ROM Drive
DVD/CD ROM does not open
I push the eject button - nothing happens
I right click the DVD/ROM icon in 'My Computer', select 'eject - nothing happens
How can I get my dvd/cd rom to open again so that I can use it?
  • 7 more comments
  • rbunhu Oct 08, 2008
  • Anonymous Oct 26, 2008
    your computer is not recognizing the CD-ROM drive.
  • reapersoft Nov 29, 2008
    My issue is similar, seems to happen after running a DVD or CD in the drive for a while. Pushing the button on the drive does not disengage it, neither does selecting eject from Windows explorer.
    The solution offered is not viable on the emachine model that I have (its a mini desktop), there is no pin hole for manually opening the drive that I can see.
    I contacted E-Machines and they gave me the typical first line support answer and directed me to a link that gives various DVD/CD-Rom solutions. Unfortunately this problem is related to the driver or perhaps some E-Machine hardware problem. I'll keep pinging them but it was $200 bucks so I figure its cheap and I'm not expecting much in the way of support.
  • Anonymous Nov 30, 2008
    I have the a similar problem, except it only happens when I first turn on the computer. I press the button to eject the DVD burner, and I hear it try to open but it does not open. It will take up to five or six tries then it opens, and it does not have any more problems the entire time I have the computer on. I looked for the hole to put the paper clip on but there is none. I just hope that it does not get stuck with a disk in it.
    My machine is a W3611 with a DVD burner combo.
  • irina_z73 Dec 09, 2008
    DVD/CD-ROM tray keeps opening & closing itself
  • Anonymous Dec 18, 2008
    My E- Machines cd-rom drive button seems to be broke.
  • tuttblt Mar 04, 2009
    I have the same problem. The unit makes the right sound as if trying to open, but it does not. When the open button is depressed, the flashing disc icon appears with the cursor even though there is no disk inserted.
    When the drive does open, it works as if nothing is wrong and continues to do so until the sessions are finished. When I boot up again, the same problem occurs ... every time.
    I have resorted to the paper clip.
    What can be done.
    Thanks,
    BT
  • weddingdoves Mar 11, 2009
    I thought at first that my E-Machine had no hole to insert the paperclip, but with more lighting, wah-la, there it was. It opens easily when the disk is in.
  • Foofsmom Apr 27, 2009
    I have an E-Machinemodel: T6216 and my DVD drive has been stuck closed for some time. I just bought a DVD burner but that doesn't READ discs just burns. So I have looked all over for this supposed pin hole but I don't seem to have one. If pried open it will open but I hate doing that and it takes forever to figure out exactly how I did it last time LOL. Can anyone help?
  • E-Machines Master
  • 998 Answers
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Posted on Oct 17, 2008
How do I open the cd player
Click the "Start" button.
Click the "Computer" icon.
Right-mouse click on the icon for the CD/DVD drive.
Click to choose "Eject".
Oct 31, 2014 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
I have a cd I put in, but do not know how to remove it from my computer need help
1. Open the Computer window on your PC: Either double-click the Computer icon on the desktop, or open the Start menu and choose Computer.
2. Click the DVD drive icon: Clicking the icon selects that drive.
3. Right click on it and choose 'Eject' from the drop-down list.
OR
Try the following only if the above steps didn't work or in times of urgency, such as when the computer is locked up (or turned off), you can manually eject a disc/cd by pushing a straightened paper clip into the tiny hole (the "beauty mark") on the front of the DVD drive.
f90a6593-7fec-4205-a633-379cc4b71e53.jpg8572a8b8-67cd-4c33-bbf8-d5d51bfdd48d.jpg8681c4da-0608-43dc-b4b8-cee760b38e11.jpg
Nov 28, 2013 | Computers & Internet
Cannot find eject button on laptop
I assume you want to eject a Disk? Usually there is a button on the DVD?CD Rom drive door. You can open the the Rom drive by opening the Computer folder in Start Menu, right click on the device Icon, choose EJECT and click.
Apr 20, 2013 | Fujitsu Siemens Computers & Internet
Cd is stuck in my gateway computer
If you open Computer in the Start Menu, right click on the DVD/CD Rom, select Eject , it still will not open? Look for a "pin-hole" on the DVD/CD drawer, near the button, insert a pager clip. If the CD has exploded, which happened to me, you will have to remove the DVD/CD Rom and dissemble it.
Mar 07, 2013 | Computers & Internet
Doesn't open when the button is pushed.
Push it harder. Then try to take your finger nail and underneath the laptop pull on it as you push the button. Restart your computer. Go to your computer and right click the icon on the cd/dvd drive and select eject. I have a Dell and sometimes the button has to be pushed in hard. I hope some of these suggestions help you out and thanks for using FixYa.
Jan 13, 2011 | Dell (6T980-A01) CD-ROM Drive
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
Dvd drive won't open
you can try opening it with paperclip if it's stuck. Straighten the clip and locate a small pinhole on the drive it and insert the clip in. You might need to push the paperclip in an out a few times to eject the drawer.
Jun 19, 2010 | Computers & Internet
DVD/CD will not open on my HP Pavllion s7000 what may cause this?
go to computer and try to right click on CD/DVD Rom and then select Eject there.. if this doesnt helps u then u would have to manually release the CD/DVD rom.. just below the tray there is a Small Hole .. use a Needle or any other device that may go in that hole.. try to press on eject button there.. and try to press using needle.. try doing so 3 - 4 times.. there is a latch that needs to be released to open the Tray..
this normally happens if the eject functionality of the tray is not functioning properly.. if ur computer is under warranty .. get the CD/DVD rom replaced.. let me know if this resolved ur issue regards, guru
Apr 20, 2010 | HP Computers & Internet
I cannot eject my dvd it doesnt play also
Look at the drive there should be a tiny pin hole near the eject button, insert a needle (saftey pin, sewing, etc.) into the pin hole and push this opens the drive.
You can also try opening my computer and right clicking the dvd drive and select eject.
Jan 05, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
2,463 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
