Nokia 1100 Logo
shaik fareed uddin Posted on Dec 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Automatically swicth off
Phone is automatically switch off what can i do for this
Anonymous
Level 2:
  • Expert 247 Answers
  • Posted on Dec 08, 2011
Anonymous
Expert
Level 2:
Answers
247
Questions
0
Helped
42546
Points
482
If your phone automatically shut off that means that the phone is not getting the power coming from the battery or the battery itself can no longer supply power for the phone. In this case, you need to try another compatible battery for your handset. If battery wont work with another handset, that means that your phone needs replacing battery.
1helpful
Samsung wave gts5253
so when did you drop it?
Sep 19, 2013 • Cell Phones
1helpful
2answers
Pye awm800 drains water but wont spin. any idea as to the cause please
The timer swicth needs to be replaced. Part of the time swicth that controls the spinnig is bad.replace timer swicth and that will fix your problem
2helpful
3110c Cant switch on
it needs to e reprogram.. please vote
12helpful
Nokia 3110 reset codes(reinstall software code)
nokia 3110 reset codes ,i m using 2 gb memory card.when i insert the memory card it automatically swicth off and on after that. after emoving card it gets normal.mamory card is ok.itz new one card..
reply soon
My nokia N73 have problem After I press switch on button phone start but after 10 second it will switch off and then swicth again then on automatically. It repeat and repeat and repeats again.
You have to format your phone.
To format N 73 Cellular Phone Steps are shown below
  1. You can remove the mmc but keep the sim card and restart your phone.
  2. Then press the keys *#7370#.
  3. The phone would ask a confirmation.
  4. Select yes.
  5. Then it will ask for a code.
  6. Type the phone lock code (the default code is 12345).
  7. There you are! your phone will restart with all the phone memory formatted.
Tips
  • Also remember that you can reset your phone but not loose any of your personal files (I.E restore the settings that came when you bought the phone while keeping contacts etc) by following the above procedure but using the code *#7780#
Warnings
  • Don't apply these steps if you are not sure what you are doing.
  • Make sure you have enough battery power before beginning this procedure.
Switch off automatically with low battery
This is the symptom of defected battery near to run out.Its appear a full charged then its swicth off automatically ,you better replaced the battery,with a new one.
Hope it may help you;
Regards;
VOTIT
Hai sir , my nokia n72 type rm180 mobile having problem with automatically switch off and swicth on. i may facing problem of virus . plz slove my problem.
Remove memory card and check. if same problem press *# 7370# on your mobile. Be sure that you have taken back all your phone data back. Phone will restart. Now check it with out memory card. if it is ok, Check your memory card for virus in computer with latest anti virus through a card reader.
N73 phone start up failed
hi.
please format the memory card. and start the phone.. it work's.. if not there is a memory card problem..please fix it. thank u..
Phone
at first you do the swicth off your mobileand remove your battery also upto 15min after swicth on your mobile then go the settings >phone settings>in that is given default settings select it after some min again swicth off and swicth on after u send the message
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
