Question about HP Office Equipment & Supplies
Printer is offline - HP Office Equipment & Supplies
    Genius:
  • 1,124 Answers
1.- Check the cables
2.- See if some antivirus program is blocking your printer
3.- Go printer folders and cancel all printer pending jobs
Turn off your printer
Turn off your computer
Turn on your computer
Turn on your printer
If still is off line...
4. Uninstall and reinstall the printer
5.- Replace the Cables (USB or similar)
6. Replace the printer
Posted on Oct 01, 2008
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
I have windowsvista and plugged my hp pcs1210 into my laptop with a usb and my printer box states my printer is offline
Reference: http://www.ehow.com/how_4796279_change-printer-offline-online.html
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
There's a small chance this might be your fix.
Hope this helps!
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online | eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz0vK6bYiB5
    May 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
    Printer Offline Message
    If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
    1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
    2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
    3) Set the printer online if it is showing offline.
    4) Now right click the printer and select "Use Printer Online".
    5) The display should change to ready.
    Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
    Jan 07, 2010 | Epson Aculaser C1100 Printer
    Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
    So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
    As in conclusion, if you want to print set the printer online.
    Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
    Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
    Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
    Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
    Nothing happens when i tried to print from my computer the status is offline what is wrong
    same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
    Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
    415 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
