Question about Dryers
Put a belt on a dryer
Need to put a belt on a proline tumble dryer tdv62 ..i have put the belt on but its alittle lose and ive heard it has to attach onto a motor spring .im unsure how to get to the spring tho!! or motor where would it b etc thanks vanessa
    Scholar:
  • 157 Answers
Hello vanessastar3. Your dryer may have a motor mount with cushion or spring mounts and they may have grown weak with age. If the dryer performes substantially this maybe the lose point. Check your belt route most units have a flate spring supported roller and this maybe your weak spot. I will need Mgfr. & model# to be more pin point to the problem area if these suggestions don't correct the problem. Have fun.
Posted on Oct 01, 2008
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Proline tumble dryer not turning. Belt intact. Drum turns ok manually. Have put in new capacitor. Started machine off manually only works short time then stops
bad motor replace the motor ive seen same thing happen on whirlpool where it will spin only if you give it a boost with your hand
Jun 27, 2010 | Dryers
Proline tumble dryer TDC6A makes a loud grinding noise.
Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
Dec 09, 2009 | Dryers
My kenmore dryer won't spin or tumble. The motor runs but no tumbling. I heard a loud bang but didn't know what happened. çould it be the belt?
If the drive motor is still running, the loud bang you heard was either the belt breaking, or slipping off the idler pulley. I will need a model number in order to give you spcific details on how to open the appliance in order to inspect and replace your belt. If you need assistance on how to properly route the dryer belt on to the drive motor shaft and idler pulley, repairclinic.com has dryer belt diagrams listed under their "Special Features" section. Just click on the "Repair Help" link at the top of their web page, to start. You will need either diagrams H, B or K. Its hard to determine which diagram without your model number. Post back with your information and let me know.
Jul 11, 2009 | Dryers
Dryer Not Tumbling
If you are talking about the front of the machine, above the SERVICE ACCESS PANEL, then after you remove the screws at the bottom of the FRONT PANEL, pull the panel toward the front and the top of it will pop out. It is in place with small GUIDE SCREWS and a couple of removeable clips.
If your barrel is not tumbling you probably have a broken BELT and it needs to be replaced. Easier to do this from the back I think. It goes all the way around the barrel of the dryer, so you have to put it on the barrel then attach to the IDLER PULLEY and SERVICE BOLT.
Jan 05, 2009 | Maytag SDE3606A Electric Dryer
Our proline tdv62 is blowing cold is this the heater element that needs replacing or could it be the thermostat please help
It could be either the element and or the thermostat(s).
The only way to find which one it is , is to meter the element and stats for continuity..
If you have a meter, set it to the ohms range, and check reading, you should get full scale deflection if they are o.k.
If no reading, then it is faulty.
Hope this helps you.
Plz rate my solution.
Thanks.
Dec 21, 2008 | Dryers
Hotpoint tumble drier TDL52S
you dont need to take the back off. to get inside, first remove the panel on the bottom of the front, that will allow you to remove the front panel and you will be able to get inside the dryer. as far as stretching the belt, i have never heard of that. there is a belt tensioner that holds the belt tight though. good luck!
Sep 24, 2008 | Hotpoint TDL15 Electric Dryer
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
106 people viewed this question
Top Dryers Experts
