Question about Coleman Powermate Powermate 5000W Generator
No power output
My generator runs but no power. After running about 16 hours there is no power output. This unit has been used twice. Each time this happened.
  • rdapple9 Oct 07, 2008
    coleman powermate 5000 watt _ motor runs & starts good but at all electrical outlets - no power
    This happened after running time of 20 hrs
  • 169 Answers
I posted an answer that may help here.
Posted on Dec 05, 2008
Briggs 6200 elite generator. Starts runs good no ac output and display is blank $14.95
May 30, 2016 | Briggs Electrical Supplies
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Apr 12, 2015 | Northstar Electrical Supplies
What faults can a change over switch caurse between the generator and the load
One consideration is how many circuits and how much total wattage is being used when the generator is in service.
"Gas Powered Generator GG2300 2300 Watts Surge 2000 Watts Continuous Output 10 Hours of Run Time at Full ."
This is a relatively small generator with 2000 watts output, so the problem may be that the generator can not handle the wattage demand. You can get a pretty good estimate of the wattage demand by adding up the wattage of everything , all lights, appliances, etc that's being powered by the generator. If the total wattage is greater than the output of the generator (2000 watts) then the generator is too small.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Generator was running fine and then the electrical output quit while the engine was running.
Sounds like you did overload the capacity of the generator. What has happened is that the generator was happily running away producing the electricity required for approximately an hour and then an appliance such as an air conditioner, furnace, refrigerator, water heater, or similar large amperage draw fixture decided it was time to kick on for its cycle, or perhaps two or three of them kicked on at the same time, thereby raising the amperage requirement beyond the capability of the generator. All heavy duty appliances run at a given amperage but when they kick on for a cycle they draw almost 50 percent or more amps. Generators rated at 6000 amps or less will not power an entire home or business. When using this size of generator, disable some of your electrical items in the home by unplugging or switching off, and only connect the most important items needed for emergency use. A 3500 watt generator will only run a few lights and a television, plus only one appliance. This means that you could plug in the refrigerator and run it until it has gotten cold enough, then unplug it & connect the furnace or air conditioner or water heater so that they can do there job. Eventually you will be able to rotate through each appliance in turn, and hope the power will return soon. Your generator will likely have blown a capacitor, resistor or some similar repairable item. Some good quality generators will have an overload breaker installed, that trips before doing any damage and all that is needed is to find it and reset it, in order to continue using the generator.
Dec 05, 2013 | Campbell Hausfeld GN5060 - 5000 Watt...
How soon after starting does it shut down?
The hour meter is fed directly from the AC output off the generator stator, if there is no AC output the meter will not run. Assuming it shutdowns quickly, check 1st the oil level and make sure the low oil sender unit is ok, wire #24 to ground. If that is bad it will shut down. Check to see if you have 240V on L1 and L2 on the breaker for the brief time it does start, that will confirm stator/rotor has an output, then your problem moves from the generator portion to either the oil sender, or control board.
Feb 24, 2013 | Powermate Coleman Standby Generator...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Portable generator outputfailure
You need to run these tests in the video and come back to us with the results. Send your test results to us here:
Then we can tell you what the problem is :)
How to test your Electricity Generator AVR Brushes and Alternator on...
Feb 27, 2017 | Electrical Supplies
Coleman Powermate Powermate 5000W Generator Logo
620 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
