Question about Toshiba Satellite A100-S8111TD Notebook
I have a Philips 19" Lcd When i swithced it on everything was fine until about 5 seconds later the screen went black. I have found that if i switch the monitor off and then on it works ok until another 5 seconds,if l look very close its working in the background but the screen is black there is no light on the LCD. when switched on the screen remains black
  • Toshiba Master
  • 787 Answers
A 19" Philips LCD prefers a setting of 1440X900 if you are too far off this it will turn itself off.
Right click on the desktop, go to settings and set it to 1440X900 and then go to advanced and make sure the refresh rate is set to 60 Hertz. Shining a flashlight on the screen will help you see.
There other thing that might be causing this is the setting on the monitor itself. Press the Menu button on the LCD and adjust the brightness and contrast.
If all else fails, contact Philips. This is a premium brand and it comes witha 4 year warranty.
Posted on Oct 02, 2008
Samsung LN37B530 37" LCD TV
Sounds like your Tcon board is giving issues.
Nov 16, 2017 | Samsung Televison & Video
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Hi,I have a LCD monitor Philips 19 inch Black. From time tot time,appear one error... NO VIDEO INPUT , and then is made black and appear "Entering sleeping mode" . What I must do? Or for where...
Check that the Video cable (VGA or DVI) is not damaged, if you move it does the screen go on and off?
If not then the circuit board inside the screen is faulty and needs reparing
Apr 05, 2011 | Philips 170S4FG 17" LCD Monitor
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Unwantred announcments in the center of the screen
This problem comes from the control switches on the front panel. I had the same problem and fixed it by opening the monitor (unscrew 3 screws on the back side, remove plastic shape of the stand, unscrew 5 screws of the stand and open the back; unscrew the 2 screws of the button switch panel). Now inject contact spray on every switch button. If the problem remains you may have to replace the button swithces. Thats all!
Oct 12, 2009 | Philips 190V6FB 19" LCD Monitor
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
Blacking out for 20 seconds over and over
The lamp is going bad. Very common for some Sony to do exactly what you are describing.
May 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
SAMSUNG SYNCMASTER 191T PLUS
I have the same problem. Have you found a solution?
Aug 24, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Toshiba Satellite A100-S8111TD Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
