Question about Canon PowerShot A520 Digital Camera
I bet you can't solve this.
I have a Canon A520. It is aesthetically perfect and was in perfect working condition until last night.
I turn the camera on while the camera is set to view the pictures (blue play symbol) on the memory card and it works perfectly fine.
I then push the switch up to camera mode (from blue play symbol to red camera symbol) and the camera either switches off or "replace batteries" appears at the bottom left of the lcd screen. I have placed several new batteries in and it still asks for new batteries....very strange indeed.
  • 2 more comments
  • slzune Oct 10, 2008
    Mine does that to. I can view my pictures just fine. But after a few seconds, my camera switched off WHILE the lens was still open. When I turned it on, the lens retracted and popped back out again.
  • susnet Oct 31, 2008
    The exact same thing happens with my A520.
  • anisa123 Dec 17, 2008
    I can view the pics I took up to just a few days ago.
    however when I go to take a pic, the screen is black, if I try to take a pic anyhow, The camera will act as tho it just took a picture, the flash will flash, and there is a brief display on the lcd screen of the view I was aiming at with my camera. when I go to view mode to see the pic I have apparently just taken, there is no pic in the history of shots. even tho the camera acts like it just took a picture.
    it seems that the lcd itself is fine, the camera itself functions fine. it seems that the connection between the lense and the camera itself is screwed.
    help!!!
    seems a shame, and I don't really want to have to buy a new camera :(
  • suherrera Jan 05, 2009
    I have the same problem. So what is the solution. Now it is saying that the memory card has no images. Did it erase it all?
We have a Canon A520 and it was having all the symptoms noted. Searched for a resolution on numerous sites including the Canon Support site. While on the Canon Support site, I found an FAQ on "How to RESET the A520". Turn camera on, find and hold MENU button for 5+ seconds until "Reset settings to default?" screen appears. Arrow over to OK and press the SET button. When we did this the battery low indicator showed, replaced batteries with standard alkaline batteries. Everything functions properly, with no additional problems for the past 5 days. I guess the camera just lost its mind and had to be defaulted and rebooted, hope this helps.
Posted on Mar 12, 2009
On my canon A520 the zoom lever appears loose and operates erratically, sometimes not working at
all but when moved back and forth it then works again for a short while the problem comes back. when this problem occurs i cannot select stored pictures in photo review mode. also cannot zoom while in picture taking mode.
Posted on Oct 30, 2008
Playback switch does not operate
PDF]Camera User Guide
gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
camerarepair.blogspot.com/.../simple-fix-for-dead-cameras-that-wont.ht...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
I have a Canon Power Shot A520 and have just put in a new memory card 4GB and new batteries. When I turn on camera is says memory card error at the top of the sceen. Why is that?
The A520 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible.
You need to use SD cards 2GB and smaller.
Oct 05, 2010 | Canon PowerShot A520 Digital Camera
Flash of PowerShot A520 not working
Nope...mine does that also.............
Nov 19, 2008 | Canon PowerShot A520 Digital Camera
Disabling wallpaper setting when downloading pictures
i assume its like the canon a530: in playback mode, push 'menu', press the right button until you get to the last tab, and there should be an option there.
Aug 20, 2008 | Canon PowerShot A520 Digital Camera
Camera problem canon A520
Did you accidentally hit the "Disp." button (lower left corner)?
Jan 21, 2008 | Canon PowerShot A520 Digital Camera
Shutter cover opens partially in power shot A520
brother the camera gear system has got problems it seems. it happens due to misplacement of gears inside it.
even tough u can do it manually dont take risk of doing it manually untill u have full knowledge of internal parts. am from chenai. here in our service centre it costs around 1800 rupees for servicing it. so better take it to service centre.
Dec 23, 2007 | Canon PowerShot A520 Digital Camera
Built in flash doesn't work
I dont follow this one Does the flash work at all? It sonds like t bad connection if it only works when it is off and wont work if it is on Canon Canon Technical Support may know about this one.
Jun 21, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A520 Digital Camera Logo
362 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
