Question about HP Officejet 7210 All-In-One InkJet Printer
Lines on photographs,
Lines are on prints of photographs despite new ink cartridge which is aligned correctly on the test. I have windows vista
  • 326 Answers
Try cleaning your printer heads in your printer settings in the control panel. might have to do it a few times and it will use your ink.
Posted on Oct 01, 2008
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
Ihave the easy 5100 and it has brand new ink
Did you run the Clean Print Head feature? Did you align print heads and make sure everything is aligned? There are a few tests you can do to make sure everything is lined up correctly. If you need help, try here:
Jan 10, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Canon BJC 3000
Printer attempts to print but no ink is on the paper Printer attempts to print but no ink is on the paper If the print quality is poor or no ink is appearing on the page, it may be because of the following problems:
  • The ink in the BJ tanks has run out.
  • The print head nozzles may be clogged.
  • The protective cap or tape may have been reattached to the BJ cartridge.
  • The BJ cartridge may need to be replaced.
  • You may be using the wrong side of the media.
To check the level of ink in the BJ tanks
Open the printer's front cover and visually check the level of the ink in all the BJ tanks. If a BJ tank is low or has run out of ink, replace it. Failure to do so may shorten the life of your BJ Cartridge
Check the status of the print heads by printing a Nozzle Check Pattern
The Nozzle Check Pattern confirms whether the inks are being correctly ejected from the print head nozzles and whether the print head is correctly aligned.
  1. On your printer, press and hold the Resume button until the printer light flashes two times.
  2. When you release the button, the Nozzle Check Pattern will be printed.
    You can also print the Nozzle Check Pattern by clicking on the Test Print button in the Maintenance tab of the printer properties dialog box.
  3. After the Nozzle Check Pattern is printed, check the results.
  4. Look at the Nozzle Check Pattern for each BJ cartridge. If any colors are missing or if any horizontal lines are broken or missing, perform the print head cleaning procedure.
  5. In the alignment head pattern, if the lines are not perfectly overlapped, align the print heads.
To perform the print head cleaning procedure
  1. On your printer, press and hold the Resume button until the printer light flashes one time.
  2. When you release the button, the print head will be cleaned.
    You can also clean the print head by clicking the left Print Head Cleaning button in the Maintenance tab of the printer properties dialog box.
  3. When the print head cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.
  4. Perform the Nozzle Check Pattern test again.
  5. If the results are satisfactory, resume normal printing.
  6. If the results are not satisfactory, you may need to execute a print head deep cleaning.
To execute a print head deep cleaning
  1. Make sure paper is loaded in the sheet feeder and the printer is turned on.
  2. Display the printer properties dialog box and click the Maintenance tab.
  3. Click the right Print Head Cleaning button.
  4. When the print head cleaning begins, the POWER light starts flashing. Wait for the light to stop flashing before you resume normal operation.
  5. Perform the Nozzle Check Pattern test again.
If the Nozzle Check Pattern is still unsatisfactory, you may need to execute a print head alignment.
To execute a print head alignment
  1. In Windows, display the Maintenance tab of the printer properties dialog box.
  2. Click the right Test Print button.
  3. Follow the instructions on the screens to perform an automatic print head alignment.
  4. A confirmation screen will ask you if you want to perform automatic print head alignment. Read the screen and click OK.
  5. Another screen warns you not to start any other operation until the alignment is complete. Again, click OK.
  6. The BJ Printer Status Monitor displays the Printer Status. The driver will align the print heads then will print an alignment pattern.
  7. Perform the Nozzle Check Pattern test again.
If the Nozzle Check Pattern is still unsatisfactory, you may need to replace the BJ cartridge.
To replace a BJ Tank in a BJ Cartridge
Leave the BJ cartridge in the printer when replacing a BJ tank. Make sure the printer's power is on. Make sure you insert the BJ tank in the correct slot.
  1. Open the front cover.
  2. The power light blinks while the cartridge holder is positioned to the center of the printer.
  3. Remove the empty BJ tank by pressing in on the release tab and then lifting the BJ tank up and out of its slot.
  4. Dispose of the tank properly, taking care to avoid spilling ink on your hands, floor, furniture, or clothing.
  5. Remove the new BJ tank from its package and pull the orange tape up and against the perforations to open the package film.
  6. Be careful not to remove the label from the tank. You will need it to match the tank to the correct slot in the BJ cartridge.
  7. Twist the orange protective cap to remove it.
  8. Do not attempt to reattach the protective cap; instead, discard it along with the protective tape.
  9. Insert the BJ tank by holding it at a slight angle, aligning it with the correct slot. Press down gently on the top of the tank until it locks into place.
  10. Lock the ink tank in place by pressing down on the circle mark on the top of the tank.
  11. Close the printer cover.
  12. The printer will automatically start cleaning the print heads. When the print heads are clean, the POWER light will stay on, indicating that the printer is ready for operation.
  13. Perform another test print to make sure the new ink tanks are performing correctly.
To remove the protective cap and tape from the BJ cartridge
  1. Open the printer's front cover.
  2. Unlock the BJ cartridge by raising the cartridge lock lever. Make sure you raise it all the way up.
  3. Remove the BJ cartridge by holding it by the circles on the left and right sides.
  4. Make sure that the orange protective cap has been removed.
  5. Make sure that the protective tape has also been removed.
  6. Replace the BJ cartridge and move the blue cartridge lock lever until it locks in place.
To check the media:
  • Make sure that you are printing to the correct side of the media that you are using.
  • Be sure to read any instructions that come with your Canon specialty paper. These instructions provide important information regarding how to achieve the highest print quality with these papers.
Dec 17, 2007 | Canon BJC 3000 InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
Ben Johnson
