I have a ACER LCD Monitor that will not power up when turned on. The power light does not come on. (AL1715)It was purchased under three years ago.
    Problem Solver:
  • 29 Answers
Check to see if the computer is turned on and that the monitor is plugged in. If all Ok, then your monitor is burned out. Do not open the monitor case and look inside because you can get a shock. Just replace it. Three years is about normal life span.
rmatheson@wowway.com
Posted on Oct 01, 2008
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Feb 02, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 no lights
We are seeing this same "issue" with this model regularly. If there is no screen and No led/lights, then the power supply has gone out.
It appears on that model there is an external power supply.
Google the model number of the Monitor for replacement parts.
Plug something into the same outlet and verify the outlet is good.
Oct 20, 2009 | Acer AL1715 17" LCD Monitor
Is there an installation CD with this monitor? I'm giving it to a friend, but don't remember what all came in the box when I bought it 3 years ago.
Well, these monitors do not require any sort of installation software. hence, you need not worry about the CD. The box would have probably included the monitor, its stand, power cord.
Rate it, if it helps.
Aug 03, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1715 power issues
I have an ACER AL 1706 monitor that would not power up completely. After pushing the power button, only the yellow light would stay on indication a power up fault. After careful inspection of the power boards caps, there was visible swelling of the 47mF and 22mF radial caps on the top part of the caps where the tiny cannisters 4 edges are folded down flat. I replaced these caps( 6 on my board) because there is reaaly no way to actually test them and bought new ones from Radio Shack. Now my Acer monitor came back to life with no other problems. I recommened using replacement caps with same microfarad values, but if the voltage rating is not exact, it is o.k. to get the next higher voltage rated caps available and should work fine.
May 01, 2009 | Acer AL1715 17" LCD Monitor
Monitor resolution problem
set your dispaly resoluiton to 1024*768
Mar 24, 2009 | Acer AL1715 17" LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
My acer,mod. 1715
Rich most likely this monitor needs capacitor replacement if you can solder you can do it, you just need to order or get the bad capacitors that need replacement so you need to open the case and get at the power board. once you can get at the blown caps you can see whats damaged and what is OK usually it is 1 or 2 capacitors at about 50 cents each. and about 1 hour of your time.
let me know what your doing, good luck
Oct 18, 2008 | Acer AL1715 17" LCD Monitor
AL1715 problem with colors
1 year warranty on parts, unfortunately the capacitors on these boards go bad and they can be replaced fairly easy if you can solder.
given your issues I think that there are some bad caps (blown) and they could be replaced very cheaply say under 100 usd + shipping for both if I do it, or for less than 30 usd if you do it.
let me know what you want to do
Sep 01, 2008 | Acer AL1715 17" LCD Monitor
17" AOpen monitor about 2-3 years old
Sounds like a backlight problem.. due to the inverter shutting down due to a fault.
Jun 21, 2008 | Acer AL1715 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Sep 02, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
70 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
