Question about Bissell 3522 PowerForce Bagged Upright Vacuum
Bissel vacuum My bissel powerforce somehow is loosing its suction Ive no clue why Ive checked for clogs etc. but Icant find the problem please help!!
  • pr3ttyg1rl Mar 29, 2009
    I have the same issue with my vacuum
  • Anonymous Apr 17, 2009
    this vacuum doesn't **** :-)
  • 281 Answers
Take the dirt cup out and turn the bottom of it that will let you get to the filter,there should be some finger twist plates on the top,turn and take it out,there will be a foam cover around the filter,take that off and clean with warm warter,when done towel dry with paper towels,now the filter itself is water friendly ,take a brush and in up and down strokes ,clean while running water over it.above where the dirt cup goes is another filter ,just reach up inside and twist and it will come out,clean that also.now put the dirt cup back in without the filter and see if you have suction,i believe you will.let the filters dry before you put them back in then reassemble,and if that don't work, the take the hose off and see if you can blow through it .if thats not it then at the bottom on the right you will see a clear hose,thats your intake hose.there is a screw on the black fitting thats connected to it ,take it out and get you a coat hanger and bend the tip so its rounded ,thats so you don't puncture a hole in the intake hose.work the hanger down into the intake hose and push out the clog .then try it again..please leave feedback.i hope i was some help to you.iwould clean the foam filteres at least once a month
Posted on May 04, 2009
I cleaned it out but it still wont **** into the dirt container it all ends up getting cloged in the opening on the bottom
Double check the elbow at the base on the right hand side (back facing you) of the vacuum for clogging.
Many times it will appear free but be packed solid at the elbow just out of sight, there should be a screw on lower right that when removed will detach let you detach the elbow from the base of the plastic tube that holds the upper attachment hose this will help you straighten it bit to free any clogging, remove the beater bar & belt, apply suction with a shop vac or another vacuum to the front tube just behind the beater bar, you should feel suction at the elbow where you detached it if it's clear. If not you may need a stiff piece of wire or something similiar to help carefully clear it out.
I've worked on many of these and they somehow seem notorious for clogging in that particular spot.
Feb 12, 2011 | Bissell 6594 PowerForce Bagless Upright...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
I have Bissell Powerforce Bagless Upright Vacuum. it doesn't suction well. I checked the belt. It is ok. may be clog in the hose.I don't no how to clean. can you help me please?
- Check the dirt cup to make sure it is empty.
- Your vacuum has 3 filters. Dirty filters will restrict air flow. The filters may be hand washed in cold water with mild detergent. Allow them to completely dry prior to reinstalling them. The white HEPA media post-motor filter is not washable.
- Lift the upholstery hose from the bottom holder. Check for suction at the end of the hose.
If there IS good suction at the end of the hose, please unplug your machine from the outlet and try the following:
- Ensure the hose is firmly pressed into the lower hose outlet on the back of the vacuum.
- Check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum. Check the belt and clean the roller of dirt and debris.
- Check the lower hose for clogs by removing the screw which attaches it and lifting the hose up to clean it out. Also, remove the larger hose by twisting it off and using a broomstick handle, push any dirt and debris through the hose.
Aug 05, 2010 | Bissell Vacuums
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuum Does Not Have any Suction
it could be clogged somewhere inside the hose. try unclogging it with a thin pole or rod.
Mar 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bad suction on bissell powerforce bagless vacuum
I took the bottom apart and it needed a new belt and that was the problem so it's fixed.
Jan 16, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless upright vacuum 6582
Check your filter. Sounds like it is not receiving enough suction to pull up the debris. If your filters are clean and there are no clogs, disconnect hose from back by the tank and see if you have suction straight out of the whole.
Dec 11, 2008 | Bissell Vacuums
Its blowing air out the air filter.no suction
Check the dirt inlet down by the brush roll for a clog. Also check the hose for a clog. Usually a clog is what causes this type of problem.
Jun 14, 2008 | Bissell 3522 PowerForce Bagged Upright...
Brush is not rotating.
Turn the vac over, remove the access plate, covering the brush roll, 2 to 4 screws. Brush roll part number is 2032032if you need it, belt is a Bissell Style 7. While you have the brush roll off, check in dirt inlet to see if it is clogged, also check the hose to see if it is clogged. You won't feel suction at the bag tube, it has to have a bag on it and the lid closed before it will create suction.
Dec 29, 2007 | Bissell 3522 PowerForce Bagged Upright...
My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Dec 15, 2007 | Bissell 3522 PowerForce Bagged Upright...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
291 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
