Question about SanDisk Sansa m240 MP3 Player
Problems uploading music
I recently reformatted my Sansa m240. I deid it because it had music from another computer on it that I couldn't delete, so I just wiped it. I loaded it up with more music, but now when I turn it on it says "Not Enough Space for Music DB, Please Free up 4 MB," and then reverts to a display that says "No Files." However, when I check how much I have stored on the mp3 player, it says I have 280 MB left.
How do I deal with this bizarre problem so I can use this thing for what it was intended for?
  • Anonymous Oct 12, 2008
    I have had mp3 for about 9 months and about 3 months back it stopped letting me put more music on it. i have tryed alot and it says there is no files when I go to artists or songs to try and listen to it but it says that there is 965.48MB taken up on it.yet i cant listen to it or put more music on.
    What should i do?
    Any suggestions?
  • 8,596 Answers
To format the player directly, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Settings from the Main Menu.
3. Select System Settings.
4. Scroll down to Format and select it.
5. Select Yes to start formatting.
Posted on Dec 10, 2008
Cannot delete music files
Try putting the player into the other sync mode (MSC or MTP), you probably put your files in one mode and his are in the other mode. Reconnect the computer after changing the mode and see if you can find them. Changing from MSC to MTP is somewhere in the menu, not quite sure on this model, but look around for it.
Benjamin
Apr 26, 2009 | SanDisk Sansa m240 MP3 Player
Sandisk 240 1.0 gb
I had this same problem. What I ended up doing was going into My Computer into the device itself and seeing what showed up. It appears a few new songs I popped on there the day after were appearing but nothing else. I deleted all the files, unplugged it from the computer and let the library update, old songs were still playing. Plugged it back into the machine and voila they showed up.
Aug 05, 2008 | SanDisk Sansa m240 MP3 Player
My m240 can't be recognized!
Please make sure that you have your device on MTP mode (auto detect)..Then the computer should be able to recognize it...To make sure its working correctly uninstall it and reinstall it back from the computer..and that should solve the problem..let me know what the outcome..
Please rate accordingly
Thank you
Computerrep
Mar 20, 2008 | SanDisk Sansa m240 MP3 Player
Can't change songs
put the player in MSC mode in settings: go to MYCOMP and open the player, go to the music folder and delete the songs.
Jan 16, 2008 | SanDisk Sansa m240 MP3 Player
Deleteing music from m240
-Plug your mp3 player into your computer using a usb cord.
-Open My Computer and look for a folder named Sansa"something".
-Open this folder and go into the desired folder[music] where you would want to delete music.
-select a song or multiple songs and press delete.
Dec 25, 2007 | SanDisk Sansa m240 MP3 Player
Help Me! Sansa m240 say only 'Finalizing Update" then turns off
Oh lol this is easy. just go onto realplayer or something then go on the tab burn/transfer then it will tell u your songs delete them all. then try turning your mp3 on and going to "settings" then go all the way to the bottom of that page then click "reset all" then go back to windows media player and put your songs on.
Dec 23, 2007 | SanDisk Sansa m240 MP3 Player
Deleteing problems
Go to My Computer>Device Name (m240)>MUSIC Folder, all of the contents are there,
If you do not see a MUSIC folder, you will need to enable hidden files and folders on your computer.
Best of Luck.
Please RATE my solution BELOW.
Nov 22, 2007 | SanDisk Sansa m240 MP3 Player
Can't delete songs
Go to Windows Media Player under the Sync tab, over on the far left should be the name of the player, click on it and find the name of the song by album title, artist, or whatever, click on the title and click delete and you should be able to delete any song you like without deleting them all
Nov 16, 2007 | SanDisk Sansa m240 MP3 Player
How do i delete my music if i cant find it?
well go to my computer(with the usb in) and clik on ur snasa mp3 player thing
then go to recordings and delete watever u dont need but how do i delete music i cant see???? AAAHAHHAHAHKKKK!!!! :(
Oct 14, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk sansa m240 mp3 player
You can connect the device to your computer and manage it thru "My Computer. Open My Computer, then open the device (i.e. Sansa m240). Inside there is a Music folder, you can delete them from here. You can also drag songs here to transfer to the player. If you are not able to see the "music" folder, you may need to enable "Hidden Files and Folders" on your computer. Best of Luck.
Sep 06, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
