Question about Compaq (241995001) Plug-In Module (Laptop) Floppy Drive
Needing to fix a compaq presario v5000
The computer still runs. the screen shut down i changed the the small battery in side the computer and i changed the lcd inverter but the screen still wont come on. and another question is there anything on the presario v5000 that would work on a compaq armada laptop.
  • brianhand Jan 05, 2009
    the screen started flashing on/off now it stays off for longer periods. It is on its way out.Help!!!!!!!!
  • 119 Answers
The screens on these computers can and will go dead after a while, afterall its an old computer..try an external desktop monitor by plugging it in the back(blue port)
If you want a new screen go here
Good luck..and if you have any questions about your armada just ask.. I have 5 of them.
Posted on Jan 18, 2009
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
Jul 16, 2010 | Compaq Presario Notebook
I have a compaq presario v5000 that gives me white screen help!!?
have you remembered to reconnect that small wire under the screw on the hinge?
hope this helps
Jun 06, 2010 | Compaq Armada 1700 Notebook
My screen stays black when you turn it on. model HSTNN-C17C which is located under the battery. Presario V5000
This isn't a desktop PC by the way. Do any of the lights come on? If not, try to run the laptop from the AC power. If the lights come on but no display, then your backlight or inverter on the LCD panel for your V5000 might be bad.
Oct 08, 2009 | Compaq Presario 5000 PC Desktop
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Sep 23, 2008 | HP Compaq Presario V5000Z Notebook
HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
Sep 07, 2008 | HP Compaq Presario V5000Z Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
COMPAQ PRESARIO V5000 POWERS OFF RANDOMLY
I do not believe this is OS related.
Dust bunnies under your bed? The CPU might be overheating. Check for dust and lint blockage in the cooling fins at the lower left rear. Vacuum the stuff out.
I have repaired 3 V5000s overheating because of dirt.
When you are trying to solve problems, remove the battery and run on AC. The battery is just another variable to complicate the issue.
Apr 19, 2008 | HP Compaq Presario V5000Z Notebook
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
172 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
