Question about Jenn-Air JES9750 Electric Kitchen Range
Meat probe not working
Yesterday i tried using the meat probe function and when i inserted and set the temp for the meat the oven turned off and the control panel said 'check meat probe'. What is the problem
3 Suggested Answers
the dr
  • 447 Answers
SOURCE: meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Posted on Sep 30, 2007
SOURCE: meat probe problem
Replace the oven sensor
Posted on May 11, 2008
SOURCE: Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Posted on Dec 21, 2010
The probe doesn't work on my JT912 GE wall oven
Test Continunity for your Probe, if it has good continuity, then you have a internal issue with the Oven... More than likely, you are going to need a Technician
Apr 10, 2013 | GE Profile JT912 Electric Single Oven
Hi my framtid 0v10 oven from ikea has ref F11 on screen it no longer works. I used the pyro setting for the first time
I've had the same problem. The manual said the F11 errorcode indicates that the meat probe hasn't been inserted properly. Ofcourse I do not use the meatprobe for the pyro cleaning, but I decided to insert it anyway. After insterting it I first took it out and turned the oven on. No effect. Then I turned it off, inserted the meatprobe again and turned it on again WITH the meatprobe inserted and PRESTO! everything worked again!
Jan 20, 2011 | Ovens
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
Oven will ask for temp probe when i am not using one. it then turns itself off.
As you did not include a model number I can suggest you insert your meat probe into it's receptacle and remove it again quickly about a half dozen times.....maybe even a dozen times. The meat probe plug is like an older style headphone plug. The receptacle that it plugs into may need to complete a circuit for the electronic control. When the probe is not in the receptacle, the receptacle contacts touch to complete a circuit. These contacts may have become dirty from normal oven usage. You will be cleaning these contacts using the probe as I explained. If that doesn't solve the problem you may want to call in a professional.
May 04, 2009 | Ovens
Control panel not accepting commands
sounds as if the meat probe jack is shotring itself. thinks the probe is inserted, adn is lookin to continue on that course. aside form letting it stand and dry out , yo may need to either disconnect or replacethe meat probe jack
Mar 18, 2009 | KitchenAid KERA807P Electric Kitchen Range
Kitchenaid single oven, error code is a picture of a push pin
its a "meat probe" not a pushpin. somehow the unit thinkd you hae a meatprobe inserted, soundslike a short in the meat probe jack( usually happens in high moisture areas, the wires swell and make contact with eachother, the replacement jack, has better insulation around the wires, you could also disconnect the wire harness from the main board assy(behind the console, if you never use the function!
Jan 29, 2009 | KitchenAid KEBC101 Electric Single Oven
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
Jenn-Air JES9750 Electric Kitchen Range Logo
55 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
