Question about Panasonic Televison & Video
Panasonic HT-990 stopped working, displays F61
    Genius:
  • Panasonic Master
  • 1,550 Answers
That code is for the audio amplifier IC damaged
Posted on Oct 01, 2008
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
· Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
After turning on Panasonic SA-HT 990 appears F61 on display and receiver turns it self off.
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 24, 2011 | Panasonic Home Theater System System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
F61 Error then the system goes dead
The battery might have broken so you might want to try buying a new one or charge it up fully.
Dec 01, 2008 | Panasonic Home Theater System System
Panasonic SA-HT 955 Home Theatre System
The F61 is the shorthand for protect mode. This indicates a problem with the output amplifier section. I don't have a listing for your specific model, but a similar one HT95 lists IC501 as the output amp chip. Check for the marking on the large black IC attached to the heatsink it may be RSN311W. If so, this can be ordered using part number: RSN311W64D-P for $95.20 from tritronicsinc.com.
Hope this helps,
Dan
Aug 28, 2008 | Panasonic Home Theater System System
F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Jan 10, 2008 | Panasonic sa-ht800V Home Theater Audio...
F61 code
yes i did see this code F61  but turned off and back on and the surround and center speakers still don't work
Jan 06, 2008 | Panasonic SC-HT720 System
Televison & Video Logo
202 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
