Question about Philips 60PP9352 60" Rear Projection Television
Convergence problem with Philips 60PP9352
I have a Philips 60PP9352 Projection HDTV.
The screen is bowed in on the left side about 4 inches and the colors are off even though I have run through a multipoint convergence. In looking at other posts I am thinking it sounds like a Convergence IC replacemnet is needed. If so, does anyone know what part # I am looking for and the avalibility of a service manual online?
FYI: I called a local TV shop and they seemed mystified as to why it was only one side.
Thank You for you help in advance.
  • Anonymous Oct 04, 2008
    my tv seems to bowed top and bottom and the colors are off
  • Anonymous Jan 05, 2009
    I have the same problem. The colors seem to be slightly off.
  • Philips Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Jan 26, 2009
  • Edward
    Edward Feb 05, 2009
    Here are some of the most common symptoms and example photos.
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
I have a 61" tely that has a really bright screen. on one side of the character there is a red outline that i have trouble shot and still persists to be there.
You might consider changing the convergence chips. They do more than just adjust convergence in your set and they're pretty inexpensive.
May 23, 2009 | Philips 60PP9352 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
I have a 51 inch phillips seeing almost a 3 d effect
Your convergence chips are toast. You will need to replace them along with the convergence resistors.
Here are some of the common symptoms when your convergence chips fail.
Screen looks 3D
Screen is bowed, wavy, etc but stationary.
Solution:
You can get a convergence kit with photo instructions from www.TvRepairKits.com
Dec 17, 2008 | Philips 51PW9303 51" Rear Projection...
Picture double an inch from the left side
Your TV most likely has a convergence problem.
Nov 12, 2008 | Sony KP-51WS510 51" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
60pp9352 convergence ic replaced multi points corrected but image squeezed
one of the resistors must be open, you cant always tell by looking if theyre open you have to remove one leg out of circuit then test them for resistance they can only be 5% out of tolerance, any more than that and they must be replaced.
Mar 27, 2008 | Philips 60PP9352 60" Rear Projection...
CONVERGENCE
Your Ics are bad and you prob have a resistor or two that have gone out too. If you are good with a soldering iron and have an hour to give up you can fix it. They are at location 7044 and 7045 on your board. They are STK 392-120's and the part number is 932212344682 good luck with you repair.
Feb 06, 2008 | Philips 60PP9352 60" Rear Projection...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
161 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
