Question about Acer TravelMate 2300 Notebook
Remove cd/dvd drive acer travelmate 2310
Anybody know how to do this. I can't find the magic screw that is holding the thing in.
The standard drive in the 2310 seems to be a Matshita U3-840D, which is a basically a piece of rubbish. I did what paella recommended, and the drive pulled out without much trouble, but has a small plastic flap attachment at the back which is evidentally a panel for the screw which holds the drive in place (this was split when I pulled out the drive... which makes me wonder whether a replacement will be all that easy to push in without opening up the entire unit and removing, then replacing, the existing screw. I'd recommend opening the laptop first if possible, and removing the screw at the back of the drive which keeps it in place before pulling it out.
Posted on Nov 20, 2008
    Novelist:
  • 169 Answers
I'm not an expert on Acer, but I can tell you that *most* CD/DVD drives just "pull" out with a little bit of oomph applied. It's just a plastic connector on the other end of the drive that connects to the motherboard inside.
Eject the drive tray, and *GENTLY* pull out with a slight bit of pressure. If you feel your muscles tensing up, you are pulling too hard and perhaps there is a hidden screw - generally, though, if there is a screw, it's in plain sight on the bottom of the case (and obviously should be removed first!)
Hope this helps - remember to rate! :)
Scott
Posted on Oct 02, 2008
How to take apart Intex 603 pump housing
You need to try 'security' bits. They come in sets with various sizes of star bits and hex bits.
Aug 18, 2014 | Intex 603 Krystal Clear Filter Pump 530...
Does anybody know Where can I get replacement screws for the mothercare spin
Best to contact Mothercare customer service they should be able to supply you with parts.
Nov 26, 2013 | Baby Gear
Ford ranger fan clutch
There may be a tool, or you jam a metal tool between two metal parts.
check these out:
Removing Stubborn Clutch fan Ranger Forums The Ultimate Ford Ranger...
Fan clutch removal
Apr 11, 2017 | 1993 Ford Ranger SuperCab
Whirlpool chopper blade completely inaccessible
Sorry you are having trouble, I put together some instruction for this issue. Take a look and let me know what you think. I would be happy to clarify anything that is confusing.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 11, 2010 | Dishwashers
Fan is out. is this easy to replace?
Fairly easy, I believe 4 screws hold it in and then the wire harness.
Moisture builds up and seems to corrode the wiring to fan contacts. Seems common in these.
Apr 17, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Screws for ACER PREDATOR front cover linkage
These screws are pretty common. Take one of the screws down to your local hardware store or small electronics store and I'm sure they have replacements.
Dec 23, 2009 | Computers & Internet
I have water in the discard container and wet grounds. They used to be dry brickets.
Hi
There are a couple of things that make wet grounds. One is a very coarse coffee. It should be like granulated sugar.
The second is your thumb screw is stripped, and needs to be replaced. Thumb screw holds the filter screen in in the brew head.
Dec 04, 2009 | Saeco Magic De Luxe Espresso Machine
To open the Samton 45Bn crt monitor
turn off power.
Get a long philips screw driver and remove the base and all fixing screws. some are hidden behind blanking plates and the com off with a sharp knife and a getle lifting at the join.
After all screws are removed the lie the screen downwards and start to pull away the backing.
you should get the case apart easily.
You must be aware of the tube holding a full charge at its end. DO NOT touch this at any point. The only thing you should try to inspect is the fuse or adjustment to the focus slant contrast etc.
AndystUK
Aug 30, 2009 | SAMTRON 55V 15" CRT Monitor
'99 Subaru S clock removal
I have the removal instructions at www.autoclockrepair.com.
Nov 22, 2008 | 1999 Subaru Forester
Descaling
Remove the filter holder (portafilter).
The manual says to unscrew the nozzle from the filter holder coupling and wash with hot water.
Mix a liquid decalcifier with water in tank at a 1:1 ratio. DO NOT USE VINEGAR! It says to fill the water reservoir.
Run the cleaniing solution through the machine - pressing the coffee button, 1 cup at a time. During each interval let the decalcifier act for 10 or 15 minutes by turning off the machine by the main switch.
Carefully wash the tank and fill with fresh water and empty 2/3 of this by pressing the coffee button.
Now let the machine warm up and empty the rest of the reservoir by rotating the hot water/steam knob.
Screw the nozzle in the filter holder coupling again.
Jan 06, 2008 | Saeco Magic De Luxe Espresso Machine
Computers & Internet Logo
980 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
