PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
Fogle Posted on Dec 06, 2011
Having difficulty finding a video converter compatible for pandigital novel 7
Sebastian Michaelis
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 30, 2011
Sebastian Michaelis
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
326
Points
Freemake Video Converter.
You'll want to use the Android option under the covert selection.
Works like a charm. :)
How do i reset to factory mode if i forgot my pattern
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Pandigital Novel 7 to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Pandigital Novel 7 and including third-party applications.
9. The Pandigital Novel 7 will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Forgot password
Go to Barnes & Noble's website on your computer and select the option to create an account. Enter your full name, email address, debit or credit card information and select a user name and password when prompted.
If you have a Barnes & Noble account, skip this step.
Power on the Pandigital Novel and tap "Settings" on the home screen.
Tap "General, and select the "B&N Account" and "Password" fields and enter your Barnes & Noble account login information.
Reading ebooks is not the only activity you can enjoy with the Pandigital Novel.
The multi-functional device will also allow you to listen to music, watch videos and browse through your favorite images.
The Pandigital has a speaker located in the back of the device and an earphone jack to accommodate your listening needs.
To get started, you will need to either download media from a computer or purchase ebooks from Barnes & Noble online.
Downloading Media
Connect the Pandigital Novel's USB cable into the compatible mini USB port on the right side of the device. Plug the other end of the USB cable into the computer's USB port.
Click on the computer's desktop "Start" menu.
Choose the "My Computer" or "Computer" folder in the desktop Start menu.
Double-click to open the "PD_Novel" drive in the My Computer/Computer folder.
Inside the drive there are four separate folders "eBooks," "Photos," "Music" and "Videos."
Drag compatible media files stored on the computer to the compatible folder inside the "PD_Novel" drive with your mouse.
For example, drag audio files to the "Music" folder.
The Pandigital is compatible with text formatted as ePub and PDF, audio files formatted as MP3, AAC, WAV and OGG, video files formatted as MPEG-4 and images formatted as JPEG, BMP, PNG and GIF.
Disconnect the Pandigital Novel from the USB cable.
Playing Media
Press and hold the "Power" button, located on the left side of the device until the boot up message appears on the screen.
Select a media option in the "Application Quick Launch Bar" at the bottom of the screen: Reader, Music, Videos or Photos.
Tap the desired song, video or image and tap "Play" or "View."
Tap the "Pause/Play" and "Previous/Next" options to control the file or go to the next listed file.
Setting Up Wi-Fi
Turn the "Wi-Fi" button, located on the top of the device, to the "On" position.
The Pandigital Novel will automatically scan for local Wi-Fi Networks.
Tap the desired network from the list of found networks.
Enter the network password, if prompted. Then tap "Connect." When connected, tap "Next" to continue.
Purchashing eBooks
Tap to go back to the home screen.
Select "Bookstore" from the home screen.
The Barnes & Noble bookstore will open in the Pandigital Novel screen.
Search the website for ebooks to purchase.
Tap on the book cover and select either "Buy Now" or "Get Free Sample."
Tap "Yes" to download the media cover to "My Library" when prompted.
Go back to "My Library" on the home screen and tap on the media cover.
Confirm to download the ebook to your Pandigital when prompted.
The entire media file will download.
http://www.pandigital.net/userfiles/file/Downloads/UG_PRD07T-1_v3.4_09-10-10.pdf
Barnes & Nobel
http://www.bn.com/
Calibrate screen
Hi Wes,
Tap "Settings" from your device's home screen. Touch "Calibrate" to calibrate your device.
Read more: http://www.ehow.com/how_12187564_improve-pandigital-novel.html#ixzz2YehEkBY6
Hope this Helps.
Please Rate if it did.
Thanks,
Gary
1helpful
9helpful
Is there a compatible flash player type for pandigital novel? is the memory of this device expandable?
If you are referring to flash memory, yes it can be expanded with flash sd memory type sd/sdhc, mmc/mmc+ up to 32gb. You can find more information on the specs here:
http://www.pandigital.net/search.asp?Mode=Product&TypeID=43&ProductID=393
Lewis
2answers
I need driver software for multimedia novel 7"
Dear there are programs that specializes in though you can search in Google will find the solution certainly wish you success
2helpful
3answers
My Pandigital EReader is frozen, it won't even go into sleep mode.
My pandigital has been frozen on the pandigital novel options for 1 full day. How can i shut it down and read the books I have?
Top PANDIGITAL Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
