Question about Lexmark Office Equipment & Supplies
Want to install my printer,can't and do not have any software
  • buzfox Oct 01, 2008
    I can not open up the link to give you the information that you asked for; here is the info;
    Lexmark X74-X75 S/N 15166079134
    Machine Type/ 4406-Fol
    Genius:
  • 3,422 Answers
I can give you the driver for it.
Please let me know the make and model no. of your printer.
Posted on Oct 01, 2008
  • 2 more comments
  • Priya darshan Oct 01, 2008
    I will be waiting for your reply.
    Please click on the below link and enter your model no of the printer there and follow the instructions to download the software:
    http://support.lexmark.com/perl/support/...
    Did you click on the blue colored link?It should open because it works fine from my side.Anyways i'll give you the link with your make and model no.
    Alright now please click on the below link:
    http://downloads.lexmark.com/en/us/index...
    Next click on DRIVERS AND DOWNLOADS
    After that page will load and then under "Three Ways to Choose Your Printer
    Search by Model"
    type in that box "Lexmark X74" and click search once you do this pg will load you will be asked to MAKE YOUR SELECTION go ahead and1. Select Zone 2. Select Country/Region 3. Select Language
    Finally click on submit and then you will have to again repeat this step After that page will load and then under "Three Ways to Choose Your Printer
    Search by Model"
    type in that box "Lexmark X74" click search.
    Next Click on "download driver"
    Next Select Your Operating System,just click on select windows and choose your OS
    After you have done that click on "download Now" and your download will start
    If you need anymore help let me know.
I have installed printer driver for Epson plq-22 but is not printing.what can I do
if you are using parallel port cable you must enable parallel port in bios. if you are using USB cable then for proper installation you must always install software FIRST then START software install, and only plug in printer when SOFTWARE tells you to as that is when it LOOKS for printer. make sure you only use the same usb port if you ever disconnect and re-connect it. you may need to go to PRINTERS and UNINSTALL any UNKNOWN device before re-installing. if you have a printer installed that you no longer use, UNINSTALL it as this can prevent a new printer working.If you insert printer first before software you may have trouble. If you also have 3rd party USB products such as Backup drive, then THAT SOFTWARE may interfere with install process and you may need to uninstall that software to make installing printer work.
Jul 25, 2016 | Epson Office Equipment & Supplies
How can i make my HP printer wireless?
Make sure your Computer have wirelesscapabilities in order to connect to the HP wireless printer. This is how to doit. 1. Insert the CD that comes withthe wireless HP printer into any computer that will use the printer. This willallow to setup the initial software and allow you to configure the initialnetwork settings. 2. Choose where to install thesoftware and which components of the software to install. Typical componentsfor HP printers include the network utility and project creation software. Ifyou already have software for project creation, you don't need to install this.You won't need to install either component for other computers in order to usethe printer. 3. Turn on the HP printer whenprompted. Don't connect it to a computer unless directed by the software. Ifthe printer isn't recognized by the software, you may be asked to temporarilyconnect it via a provided USB cable. 4. Choose a printer name and an IPaddress. The IP address can be dynamic or you can create a static IP address.For larger networks, dedicate a static IP address or allow the HP software tochoose a static IP for you to prevent conflicts on your network. 5. Press "Continue" tocomplete the wireless HP printer installation. The entire process can take upto 30 minutes if you install all software components. 6. Install the printer on othercomputers by going to "Start -- Printers and Faxes -- Add a Printer."Choose "A Network Printer" to view a list of network printers. Choosethe printer name from Step 4 to install and access the wireless printer.
Jan 10, 2011 | Office Equipment & Supplies
Problem with instalation
Whenever you install a printer you should install the installation software that came with the printer before you connect the printer. Usually the installation software will tell you when to connect the printer and then it will configure it and print a test page. I would go to add/remove programs and remove any remove any software you have installed for the printer. Then remove the printer from the control panel at the printer icon. Then disconnect the printer and re-start the computer. Now use the installation cd and follow it's instructions.
Sep 26, 2009 | HP LaserJet M1120 MFP All-In-One Printer
Message about software not in effect
First - did you have the printer turned on before installing the software? Printer MUST be ON!
Second - did you install the software before plugging in the usb cable? Printer must be on when cable is plugged in, and should not be plugged in until installation software says to plug it in.
Third - you must completely uninstall any previous printer installations you've done for that printer before attempting another installation. If the printer doesn't work after an install, you must delete the printer under "Printers" in the control panel, and check to see if you need to uninstall the software through the Add/Remove programs portion of the Control Panel. If you do a new install over a bad install, the printer still will NOT work. You must meet ALL these conditions to make the printer work.
Last, but not least, download the printer software from the manufacturer and not from a third part vendor, and make sure you select the correct operating system when you select the software to download.
Apr 20, 2009 | Compaq A1500 All-In-One InkJet Printer
How to install a printer without software
Installing printer means installation of suitable software to make the printer run.
YOu dont have the Software???
no probolem
go to the following link and download its software..
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14082&prodoid=24875245&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=27&y=9
beset regards,
Dec 06, 2008 | Epson Stylus CX3200 All-In-One InkJet...
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Cant install printer without disk
You need to download the driver software ( same you got in the disk ) from Lexmark website.
Download software into the computer where you are going to install the printer. It is important that you do not connect the printer before installing software.
Install the software downloaded and connect printer only when explicitly required by software setup program.
Here is the driver download page , select your windows version and start download.
Regards
Jun 04, 2008 | Lexmark Z640 InkJet Printer
The computer can not communicate to the printer after installing the software.
Did you install the software first, and then plug in the printer? Or did you connect the printer and then install the software? For most newer USB printers, you need to install the software before you plug the printer into the computer, then at a certain point, their software (not Windows) tells you when to connect the printer.
Apr 21, 2008 | Computers & Internet
Installation software
Go to the Canon web site and download the latest driver for your machine. Install it and your printer should work fine.
Sep 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
