Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
WHERE CAN i FIND Free firmware for my flash drive jetflash TS1GJFV30
Jetflash TS1GJFV30
it was corrupted when i accidentally pull it when i was formatting a comp....
plz. help me sir
  • bsvinod Mar 06, 2009
    jetflash TS1GJFV30
    it was corrupted because of virus
    plz. help me sir
  • medim Mar 18, 2009
    my computer does not "see" my transcent 160gb sata drive. the blue led is on but not blinking. please heeelp !!!
coolfixya
  • 82 Answers
SOURCE: drivers for jetflash TS1GJFV30
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#2
here you can find the software..
Posted on Feb 28, 2009
My 1gb transend pendrive is show insert disk
hi Gagan,
please remove the covers carefully and check the soldering points of metallic parts and pen drive pcb some times the middle two pins are broken.
if yes you can re solder it with soldering iron and relevant soldering aids.or ask someone to do so.
then clean the printed circuit board with electronic contact cleaner.
most of the time i found the pen drives with broken pins.
Good luck.
let us know the results.
regards.
nuwan
Apr 06, 2013 | Transcend TS1GJFV30 - 1GB JetFlash V30 USB...
I have 2 .0 GB pendrive same is not formatted
If the flash drive can not be formatted, there are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps.
Dec 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Read-only files and how to them?
Possibility
Firmware flash drive corrupted (the disk is write protected).
Solution
To repair damage to the firmware, the solution can be found on google seach engines. Example; Fix transcend flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
Dec 15, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 4 gb pendrive is write protected .how can i remove the write protection
When formatted, the disk is write protected (there is damage to the firmware)
Damage to the firmware, there are two types of
1. Damage the firmware, data can be saved
2. Damage the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and repair the firmware.
Nov 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Removing write-protectiion
1. Damage to the firmware, data can be saved
2. Damage to the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and firmware repair.
Oct 24, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My trancend 8 gb has become write protected. I used the regidit formula but the problem continued
Flash drive is write-protected, meaning there is damage to the firmware. To repair damaged Transcend firmware, use JetFlash Online Recovery software.
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download)
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
I hope this information helps.
Before repaired
After repair
Oct 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
1,079 people viewed this question
Top Transcend Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Ben Slimene Aymen
Ben Slimene Aymen
Justin
Justin
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
