Question about Honeywell Wide Breeze 16" Oscillating Stand Fan - Black
Stopped working I have a honeywell fan. It was working fine last night. but some time during the night, it stopped working. Usually, i have it going all of the time. how can i get fixed.
2 Suggested Answers
bayyagg
  • 1672 Answers
SOURCE: i have a honeywell upright
The problem would be the burn out thermistor(FUSE), it is located in the winding of the motor itself. Before that check the wiring connection in the speed switch, the main line might have cut off.
Using the tester, check the continuity of the fuse. You can't see the fuse, it is mainly covered and connected in the capacitor line.
The cause of the burned fuse is overheating, the shaft bushing needs oil or have to be replace!
Hope that helps you out!
Posted on Jun 09, 2011
NOTIFIER SMOKE ALARM PROBLEM WITH CHIRPING ALL NIGHT
Could be time for a battery replacement unless these units are hardwired
Dec 14, 2012 | Honeywell Notifier Sib-2048 Fire Alarm...
I have Honeywell T8011R programmable Thermostat. Turn AC on last night for first time...working fine...came back late morning to find display and fan off. Check circuit breaker...on. I took it off and...
Hello, first you must verify if you are getting 24 volts to the tstat at the secondary side of the transformer, if not you have a bad transformer. If you are getting 24 volts then check the batteries in the thermostat.
Apr 12, 2011 | Honeywell Programmable Thermostat Heater
Sometimes during night several times try to start
it sounds like the fflame sensor needs to be replaced, however if the unit has fan assited combustion you may also have an issue with the pressure switch. hope this helps
Nov 02, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
Jun 23, 2009 | Panasonic NN-T654SF Microwave Oven
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Wide Breeze 16" Oscillating Stand Fan - Black Logo
53 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
