Question about GE Spectra JGBP35 Gas Kitchen Range
All 4 igniters are clicking and all 4 burners work, however the igniters will not turn off.
  • lisawheeler Oct 01, 2008
    I was told that the noise would eventually stop. Then I read that something may be wet, and to try baking something to dry it out. It WORKED! We have muffins and a quiet kitchen - phew! Thanks!
    President:
  • 2,712 Answers
Glad you got the problem solved!
Posted on Oct 04, 2008
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
My whirlpool range ss630per-1 burners will ignite except of front right which give no ignitor sound at all, but the Rear Right works fine. any solutions?
Each burner control knob has a built-in switch that controls the igniter. It appears the front right burner switch in the knob is possibly defective. They are replaceable but it requires dis-assembly of the range front. Are all the igniters in a sequence? Have you tried turning the front right burner on while another burner has the igniter on. This may let you ignite the burner automatically. When you have another burner igniter clicking try turning on that burner. If the range has rectification igniters that will not work.
Sep 26, 2009 | Kitchen Ranges
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Jan 04, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Burner
You probably have an open or shorted igniter that burner. Check the igniter if defective replace it.
Sep 15, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
GE Spectra JGBP35 Gas Kitchen Range Logo
85 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
