Question about Brother XL-3500
Brother sewing machine xl3100
Wolud not pick up bobbin thread this is the first time this has ever happen i had this brother since 1997 i always oil it does it want servicing tell me what can i do.
  • Anonymous Nov 30, 2008
    I have the same model, my sewing machine siezes up every couple of stiches and I have to use the manual to unlock it...any ideas?
  • niki33 May 11, 2010
    i have a brother sewing machine that would not pick up the bobbin thread
    help me fix it
  • 5 Answers
Make sure your bobbin case is seated right.  It is easy to get it in backwards or tilted, and then it won't pick up.
Posted on May 25, 2009
My brother sewing machine special edition XL_5700 not picking bobbin thread
when installing a full bobbin make sure that there is at least 6" of thread outside the carrier slot
other than that check the needle /hook timing
Jun 18, 2016 | Brother Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My bobbin isn't working properly it clumps up...
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? ,,
May 22, 2015 | Brother XL-5340 Mechanical Sewing Machine
My bobbin won't move to add thread to it
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever?../
Feb 09, 2014 | Brother CS-6000
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
My needle isn't picking up my bobbin thread. I have not sewed in a looooonnnnnngggg time so I need help. The machine works great because my mom used it before she gave it to me.
Have you changed the needle? Do you have it inserted with the flat side facing away from you, towards the back? Double check your threading, and hang on to your top thread when the needle goes down into the bobbin area to pick up the tail of your bobbin thread. If, you do not have the manual go to www.brother-usa.com and download one for free. Click on home sewing machine support and find your model number. I suggest saving it to your computer besides printing it out, then you always have a copy. You never know how long the company will keep the manuals for free. Good luck and happy sewing
Oct 06, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother VX 1100 will not pick up bobbin thread...have cleaned and oiled machine and replaced bobbin case, could it be timing? It sure looks like it wants to work but just wont grab the bobbin thread.......
Replace the new needle, making sure the flat side is to the back of the machine.
Hold on to the top thread as the needle lowers and raises.
If it does not catch the bobbin thread, the timing may need adjusted.
You can find a graphic for adjusting the timing at sewusa.com, or take the machine in for service.
Mar 10, 2010 | Brother Sewing Machines
Brother bobbin tread will not pick up
when i sew the thread keeps cutting help
Jul 29, 2008 | Brother XL-3500
My needle won't pick up the bobbin thread
My sewing machine is a Brother LS1217, well actually it is my son's, and he uses it very seldom. I went over to put in a new needle and I cleaned it top and bottom, put in a new bobbin, and a new needle and the needle won't pick up the bottom thread. What am I doing wrong? Please help me!! It has to be something simple, as this is such a simple machine! roseandjimmy@yahoo.com
Jan 11, 2008 | Brother LS-1217 Mechanical Sewing Machine
Brother XL-3500 Logo
379 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
