My son accidently flushed a aircontioner remote controll down the toilet and it is clogging the toliet i have tried plungging the heck out of it what do i try now?
  • 943 Answers
Hi.Thanks for the question I think you need a plumber, because the toilet may have to come out, and remote dislodged, and removed. thanks the appliance doc
Posted on Oct 01, 2008
Kohler toilet not flushing completely
You have a partial clog, as if someone tried to flush paper towels or something that shouldn't have gone in the drain.
Try plunging, first, then a toilet snake, or you may have to get a pro to pull the toilet off the floor and run a larger snake if it's further down...
Mar 12, 2014 | Home
Last toilet flush did not take. (It was a bowel movement, but not excessive toilet paper.) Bowl fills, water does not go down. I have plunged entire bowl filled at high level twice. It feels like air...
Sorry to read about your problem, I hope this helps you out.
if the plunging does not work, you will need to have a rotor-Rutter , their is a clog down the line
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Kohler - Toilet - Two-piece - Highline -...
My toliet is clogged and can't get the water to flush. i have plunged, empyt out the water, not sure what else to do...
sewer line is clogged get a pipe snake find the acess hole to ur sewer line outside and insert the pipe snake stick it all the way in and then go the other direction! this should clear it!
Nov 08, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet is clogged . Plunging hasn't cleared the clog. Water drains quickly but don't get the gulp that all has flushed. What should I do other than take a sledge hammer to the Jacuzzi toilets and...
Pull the toilet up and look underneath it for a toy that got stuck. Also, look down the waste pipe for a toy that got stuck or for tampons.
Your not supposed to flush tampons down the toilet, because they are super absorbent and get stuck down the pipe, which inhibits waste flow. Especially the tampons with wings, cause they grip on the the side walls like the Dickens. You can rent a drain snake and send it down the waste pipe a few times to clear the clog. Make sure the bathroom vent is on and the windows open, because the smell is most disagreeable.
Alternatively, before going into this invasive procedure-you can go to Ace hardware and buy a bottle of Liquid Fire and pour it down the toilet to see if that clears things up. You can also order Liquid Fire online. This stuff dissolved a python rather quickly that had gotten into the waste pipe and clogged the thing up.
Cheers old chap.
Oct 10, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
American Standard Cadet 3 - bowl water slowly drains
try putting some food coloring in it to see if it's leaking anywhere. the coloring will help you identify where it's leaking
Aug 21, 2009 | American Standard Cadet 3 Right Height...
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Our toto toilet wont flush the water down. We plunged it to no avail, then we ran drain clearing baloons it wouldnt clear out. we keep removing the water with plastic pots. So we can try something else....
Sounds like something is either in the bowl stuck or down in the waste line. I would probably pull the toilet and pour water down the waste line to see if it backs up or set the toilet up on something and pour water into the bowl to see if it comes out. At least it will help to find out where the problem is. Have you lost anything recently that might have fell in the toilet. Did something come off of the plunger and get stuck in the bowl?
Feb 19, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
