Question about Sony UP DR100 Thermal Photo Printer
Printer constantly says Paper End
I put a partially used ribbon in along with a partially used roll of paper. The UP-DR100 doesn't seem to have a problem with the ribbon but the display keeps saying Paper End. I've put the paper in just like the manual says but still no luck. Is there something on the start of a new roll that would clear this message? Unfortunately I don't have a new roll to try. The display also says Paper=0 when I push the menu buttons but I don't see a way of changing this.
Any advice would be greatly appreciated.
Yes I did find a solution but why should I tell you so you can turn around and charge someone else that may be having the same problem? It looks to me like any assistance from you would have cost me. Thanks for nothing.
Posted on Oct 02, 2008
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
How can I change the paper. I cannot find the correct slot to install the new paper roll
Press down on the button located on the side of the terminal to unlatch the
paper roll cover, then lift the cover up and back
Remove any partial roll of paper in the printer tray by lifting up
Loosen the glued leading edge of the paper or remove the protective strip
from the new roll of paper. Unwind the paper roll past any glue residue.
Hold the roll so the paper feeds from the bottom of the roll
Drop the paper roll into the printer tray.
Close the paper roll cover by gently pressing directly on the cover until it clicks
shut, allowing a small amount of paper past the glue residue to extend outside
the printer door.
To prevent the paper roll cover from damaging the print roller, always gently press
down on the printer dust cover to close it.
g+ypssoexzf1qaaaabjru5erkjggg==
Mar 18, 2011 | VeriFone Omni 3700
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Blank paper coming out
Could paper be upside down? The rolls may be wound wrong. Thermal paper only is sensitive one side. Rolls might be defective.
Apr 26, 2010 | Sony UP DR100 Thermal Photo Printer
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Zebra TLP 2844 tis not detedting the paper.
It turns out that I kept overlooking one printer setting. It was set for thermal printing rather than direct.
Mar 19, 2009 | Zebra LP 2844 Thermal Printer
Troubleshooting Argox OS-214 Label Printer, Support
Your ribbon is not firm enough - roll the ribbon at the top until it is firm. If it is too loose it will stick to the paper. Follow directions to ensure that ribbon is installed properly.
Jun 06, 2008 | Argox OS-214 Label Printer
Ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
May 30, 2008 | Sharp EL-1801P Calculator
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Sony UP DR100 Thermal Photo Printer Logo
194 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
