Question about Fuji FinePix A340 Digital Camera
I was given a finepixA340. Seemed to be doing fine till I tried uploading and not only lost the pictures on my mac but camera said card not initiated so I hit the display/back button and the on butto
I do not have the manual as it did not come w/ the camera so I'm at a loss as to what is wrong. I'm massively confused by all the digital mumbo jumbo and nothing is simple. I just want to be able to use the camera.
SOURCE:
  • 203 Answers
SOURCE: my xd-picturecard is not working
see if there is a format highlight in menu of camera-this will format card to camera and should make it compatible-format will delete all data from card!
Posted on May 21, 2008
SOURCE: card not initialized
Thanks- that did work, but all my pictures got erased. Oh well, at least everything works now :)
Posted on Jul 26, 2008
SOURCE: Camera turns off when I try to take a picture!
when turns off it means the battery is low.
Posted on Aug 07, 2008
SOURCE: initializing xd card
Put the camera into play or review mode then hit the ok/menu button on back and format the card. This will erase all of your photos so make sure you've backed them up or download them.
Posted on Oct 18, 2008
jose_jersey
  • 50 Answers
SOURCE: display says card not initialized when a new xd
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/ you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Posted on Jul 08, 2009
Card Locked!
on the side it ses lock you have to un lock it theres like a butten
Jul 16, 2010 | Samsung S860 Digital Camera
Card not initializing then wont format
Hi
It sounds like the card is faulty (it does happen). I had one that acted similarly. You could try using the card in another camera to check - I have a card that works OK in Olympus camera but not at all in Fuji!
Best of luck
Martin
Sep 12, 2009 | Fuji Finepix Z20fd Digital Camera
RAW images won't upload
Are you using the camera to upload the photos? I recommend that you get a SDHC reader(USB) and copy the files off of the SD card onto your harddrive. it is a common problem that RAW images cannot be read by windows or certain programs. Photoshop CS3 and later are able to read and open the RAW images from this camera if your "camera raw" portion of adobe is current. it is good practice anyway to load your photos directly from the SD card. I had a G9 since it first came out and now i have a G10--i have never even attempted to upload from the camera. don't let this discourage you from shooting RAW because it is the primary reason in my opinion for owning a G9 or G10. Let me know if this does not answer your problem...dj
Jan 17, 2009 | Canon PowerShot G9 Digital Camera
Memory card is stopping my camera working
Check the memore card. The write protect switch has been moved.
Jan 04, 2009 | Olympus FE-210 Digital Camera
How do I initialize a picture card?
Turn the camera viewer on (on your finepix 3800, it is the middle position where you preview photos). Press the "menu" button and you will be presented with four options, and the top option is FORMAT. Select format and your card will be usable again. Two things to keep in mind. Any pictures on the card will be lost, and when you press the menu button as I described it may take a few seconds before those four options appear. As an FYI, the most common cause of the card needing to be reformatted is when the pictures are loaded to a MAC computer and the USB cable is pulled before you eject the camera.
Nov 02, 2008 | Fuji FinePix 3800 Digital Camera
Fuji A340
I had the same problem and downloaded a firmware upgrade from the Fuji web site and it now works in the camera.
Jul 18, 2008 | Fuji FinePix A340 Digital Camera
My xd-picturecard is not working in camera saying that card is not initialized My memory card worked fine the first time I took pictures with it, but after taking it out to upload them and then replacing...
May 21, 2008 | Fuji Finepix F50FD Digital Camera
Fuji FinePix A340 Digital Camera Logo
130 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
