Pink tint on Dell 1704FPT Flatpanel LCD
suddenly my monitor had a pink tint. I tried to adjust it over the monitor settings, but nothing seemed to help.
What can I do?
My Monitor display has a pink tint to it.
  • rickurd Oct 06, 2008
    Dead backlight
  • orle8050 Nov 29, 2008
    I have the same problem. I have an Xerox XG 9D with and Radeon 9250. All of a sudden, I have a pink tink throughout the monitor. I have check the cords and still nothing.
    Problem Solver:
  • 7 Answers
Unfortunately if you have tried a different machine (it could be a bad video card) and tried the cables most likely it is the screen itself. Typically when one of these lcd's begin to fail the pixles no longer access the blue field and you see mostly red instead of the other two colors. In short pink screen is terminal, it will last for a while longer.
Posted on Apr 01, 2009
    Scholar:
  • 124 Answers
Check your connections on both ends. You have a loose cable. Make sure that you screw it in on both ends snugly to prevent it from moving around. Good luck!!
Posted on Oct 01, 2008
  • Chris Brewer Oct 05, 2008
    Would you be so kind as to rate my answer? I took the time to help you. Could you do the same? Thanks.
  • Chris Brewer Oct 06, 2008
    Why only a "Thanks for trying"? What ended up being the problem?
2 Suggested Answers
SOURCE: Pink tint on Dell 1704FPT Flatpanel LCD
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Posted on Aug 22, 2008
Yellow pink tint screen
Have you tried set-up on the remote? Do that choose picture and adjust the brightness.
good luck
kolbrun
May 03, 2014 | LG 42LC2D 42 in. LCD HDTV
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Lcd screen has pink tint
Hi Friend, In this case I would recommend you to please connect any external monitor to the laptop and check if the same issue happens on the external as well.
  • If the external one also has the same pink tint then try and update the video drivers for the system.
  • If the external display is fine without any tint, then, I believe the issue is with the LCD of the laptop itself, you can try restoring the screen to factory settings and check if it helps.
Otherwise, I would recommend you to please get in touch with the vendor itself.
Please let me know if it was of some help.
Thank you.
Jan 06, 2011 | Acer Aspire 5610-4648 Notebook
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
My monitor has a pinkish tint to it. I've tried adjusting the settings and turning down the red but it is still pink. Any suggestions?
Anything magnetic close to the monitor can cause this happen. Make sure there is no magnetic interference.
Jul 21, 2009 | AOC LM742 17" LCD Monitor
Dell E193Fp Blue Screen
It can be due to the effect of some kind of magnetic effect.. If your monitor has the degauss feature then degauss it ONCE and see if returns to normal. Do not use degauss feature more than once in less than half an hour. It can damage your monitor.
Nov 16, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Apr 23, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell Flatpanel turns on and off repeatedly
Yeah, try plugging the unit into another computer to see if it's doing the same thing. That will help you to determine if it's the monitor or the video card. Next, see if replacing either the power cable or video cable (I'm assuming you're using the analog and not the digital connection, here...) to see if it might be a pin that's loose, dropping the signal strength enough to lose the feed.
Nov 09, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Computers & Internet Logo
1,393 people viewed this question
David Payne
David Payne
