Question about Fisher and Paykel GWL11 Top Load Washer
Fisher paykel dishwasher double drawer
I recently purchased a double drawer dishwasher, but I need a coupling for both drain lines into one...where can I get this? is it something special or a y connector?
thanks,
JB
  • 706 Answers
Download this manual from Fisher Paykel and examine the parts list for a hose joiner ( mergese two into one) This link provides you with contact information from the manufacturer but if you have a Lowes department store nearby, they carry that brand and can probably get you the part you need...
http://www.fisherpaykel.com/dishwashing/index.cfm?productUid=41320F55-BAF2-B7E5-DA33A5CE6070C7EC&section=supp
Also: Have you tried contacting the place that sold it to you for a replacement? They may be your best bet...
Hope this helps you..
If it does, please rate my response accordingly.. Thanks
Posted on Oct 02, 2008
The trays under myKitchenAid double drawer dishwasher leaks and holds water which sometimes leaks into floor, what could the problem be?
Either the water line to the dishwasher or the drain line out is not properly sealed. You need to access those lines (they're usually underneath) and check that all connections are tight.
Oct 06, 2017 | Dishwashers
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
My Fisher & Paykel double dishwasher won't drain completely
It may be a blocked hose. First point to check is under the sink where the thin corrugated drain hose joins the sink drain. If it is a double dish drawer there will be two hoses, one black and one white. The black hose is usually from the top drawer. They are held on by spring clamps.
If this is not the problem, post again.
Feb 07, 2014 | Fisher and Paykel Dishwashers
I have a small piece of plastic stuck in the drain hose of my fisher paykel top dish washer drawer. I have tried cable wire but it does not budge after about 3 inches. Is there a way to remove the bottom...
There are two pieces of drain house in a double drawer FP dishwasher. The one from top drawer, the one from bottom drawer which then merge into a U adapter before hoing as a single hose into the kitchen sink.
I don't think anything can be achieved by taking the bottom drawer out. If the obstruction is in the top drawer drain hose, you will have to take that out and turn it over and disengage the hose from the bottom of the sump. Your best bet is to refer to this install guide on removing the drawers. Refer page 7 step 2.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Use reverse method to put it back in. Make sure you keep a stool nearby to hold the drawer in place and not let it fall on the floor. The cables and hoses are very tight and need care when handling.
Jan 09, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Keep blowing fuses
This means there is water collected on the base of the dishwasher cabinet under the bottom drawer. You will need to disconnect the dishwasher mains plug and take the bottom drawer out to dry the base out. Follow instructions in this manual (page 7 step 2) to remove the drawer.
Jan 08, 2014 | Dishwashers
How do I check the drain hose?
If it is a double drawer dishwasher then there are two hoses one from top drawer and the other from lower drawer. They combine under the kitchen sink using a U adapter. Need to find which one is choked (assuming kitchen drain is ok and you have no inskinerator being used). Disconnect the U adapter from kitchen drain and empty tie to an empty bucket. Run each drawer and see which one is causing the block. (just a rinse cycle should be ok).
Dec 22, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel GWL11 Top Load Washer Logo
149 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
