Hi did you get my message regarding the mitsubishi with 2-3 error code
I checked the picos and they are fine is there anyting else i can check.....
flyback solder ok...horiz trans ok......conv ics ok.......
  • 8,617 Answers
It could possibly be the HV splitter or even possibly One of the CRTs shorted. I would recomend getting the service manual and troubleshooting the standby and start up circuits.
Posted on Oct 01, 2008
I have a mitsubishi rear projection and im getting 2-2 error codes , tried replacing the 2 ICs and pico fuses and still doing it
Make sure +24V and -24V are present in power supply and being supplied to convergence output chips to solve 2-2 error problem.
Thanks.
Feb 13, 2011 | Televison & Video
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
TV will not turn on 2-1 and 2-2 error. ws65807
Mitsi has this information posted in regards to the 2 errors you have indicated. "2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies)" Also these 3 tech notes were found. "1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB.
2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB."
I hope this points you in the right direction.
Apr 19, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55809 2-2 code
look on the center board where the ics are and check F9A04 and F9A05 pico fuses, if they are blown you will need to replace those two 5 Amp picos and the convergence Ics
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55859 projection tv with 2-3 error code
did you change the two pico fuses F9A04 and F9A05 when you replaced the Convergence ICs
Sep 25, 2008 | Televison & Video
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
