Question about Gateway 450SX4 Notebook
Gateway problem hi i have a gateway laptop that i cant get to load windows it asks me if i want to press f2 then says there is a problem and goes on gateway sign and thats it i cant do no more with it, plz help thank you.
    Genius:
  • Gateway Master
  • 1,250 Answers
Go to the bios and select first booting device cd
Posted on Oct 01, 2008
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
My Gateway m-7315u keyboard is not working correctly
Has there been a spill? May be a hardware failure? Try re-installing driver at: http://support.gateway.com/us/en/product/default.aspx?partNumber=M-7315u Are ALL the Windows and Gateway Updates installed? May be a "fix" in the Gateway drivers list.
Feb 04, 2013 | Gateway M-7315U Notebook
My gateway is stuck in configure 3 of 3 at start up
Turn on your computer. If your computer is already on, then reboot it. You need to see the initial display screen to get into the BIOS. Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information. The majority of Gateway computers use the F1 key. If, for some reason this does not work, then use the F2. All of Gateway's desktops use the F1 or F2 keys. this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Jan 22, 2013 | Gateway Computers & Internet
Hi i have a gateway mt6705, trying to restore to new. push the on button and gateway comes across the screen. then goes to a blank screen with a blinking line in top left corner thats it. cant use cd to...
The way to restore Gateways is to hold down the ALT Key andrepeatedly hitting f10 then it should bring you to a boot sequence screen thenchoose the HDD and then hold down ALT and repeatedly hit f10 again that shouldprompt the restore feature for gateway. If that doesn't work,the only way to doit is to boot into windows and run the Recovery program.
ALL DATA WILL BE ERASEDON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THEPOWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURINGTHIS PROCESS.
Hope this helps,
Feb 26, 2011 | Gateway MT6705 Notebook
Hello Sir/Maam: Greetings! Im from the Philippines and i have my gateway laptop here. It just stopped after i turn off. After i turn off after a few minutes i put it in my Bag then open it after a...
If you have access to an external display, plug the VGA output from your laptop into it to ensure the laptop is OK.
If the laptop is OK and it is the laptops screen that is faulty, check ebay for a replacement screen.
Having an LCD display with a VGA input is a sure way to find out where your fault lies.
If the VGA screen does not work, then maybe the laptops display driver is corrupt. Go onto the Gateway web site and down load a fresh driver with a working laptop and copy the driver onto a USB Memory stick, set your laptop to boot from USB and load the driver into your system.
If that doesn't work, take it to a repair shop for an estimate of just look on ebay for another one and copy your files to the new one.
Oct 16, 2010 | Computers & Internet
Gateway laptop wireless button
Hold down Fn key and hit F2. It will be used to turn on and turn off the wireless switch.
If you have window vista, Click Start, All Programs, Accessories, Window Mobility Centre, Turn Wireless On.
Apr 15, 2010 | Gateway T-1625 Notebook
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
Scrren Goes Blank after the booting
Hello. Put your primary boot to hard disk.
Feb 22, 2009 | Toshiba Satellite M115-S1061 Notebook
Computers & Internet Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
